When I installed Platinum 17 on Win 8 installation was interrupted with the statement that certain parts couldn't be installed but if i wanted to I could continue with install. I did that but when I work on my own cards, it quits and has to be restarted. Also, soooo many of the fonts aren't there any more that were there before.
SOURCE: CD/DVD drive will not recognize the CD
Try other CD's that you have and see if it read those or automatically run. If you tried other CDs and they can be read then it maybe you may have to inspect your Printmaster CD for scratches or clean it off if dirty. If your CD Rom doesnt read Any CD at all then maybe it may need a little cleaning inside or that you may need to replace it.
Are you going to reinstall after?
If not, delete the program files folder, and run ccleaner's registry tool.
http://ccleaner.com
SOURCE: uninstall PrintMaster Platinum 15 but have to reinstall access de
Make sure you can see all the files. (My computer --> Tools --> Folder Options ---> View (tab) --> <Select 'Show hidden files ...' option.
Find the folder you have indicated.
C:\DOCUME~1\Jan\LOCALS~1\Temp\{A35C2323-3CEA-405C-9569-EF5DDE930B2F}
Delete that flder.
Restart the computer and reinstall the software.
SOURCE: is there a manual with the Printmaster 17?
you can download the manual from my website
http://tricia8765.fatcow.com/COMPUTERTRAINING%20MANUALS.htm
you will see it is around the fourth entry on the link
SOURCE: I have Print Master Platinum 15- 5 CDs only - no paperwork
The install is pretty straight forward. Just start with disc one or disc labeled install cd (or similar) The manual is just guidance and not needed unless you prefer to reference to it. If you do need it you can visit the support section of the Print Master website to download a new copy.
Thanks Live-Tech 1-888-361-8511
http://www.mylive-tech.com
