SOURCE: Onkyo tx-sr800 PROTECT mode
Hold video1 and press speakers A button, it will say "clear" If the message protect appears again, then its service time.
SOURCE: onkyo ts595 goes into protect mode with volume increase
HI check your speaker cables are not touching, also make sure "b" speakers are not on and that all your speakers are 4ohm or higher as this will cause the amp to shut down if they are to low an impedeance,The amp is protecting itself when it shuts down.
hope this helps.
CABLE GUY.
SOURCE: stuck in protect mode
i believe protect mode is because you have the wrong impedence speakers, they are too low (4 ohm? 6 ohm?) it chols work with 8 ohm speakers
SOURCE: my onkyo receiver (tx8511) keeps going to protect
Hi there
To answer your question;
Your amplifier goes into protect mode when it detects a fault or condition that could damage the speakers and/or the output stage.
Often caused by shorted outputs.
Although this does`nt tell you much on how to fix this problem, the best help i can give you at this point is to tell you to have it looked at by a repair shop.
Hope this help good luck
SOURCE: How do I reset from the amp protect mode Onkyo receiver TX-SR600?
How do I reset my amp / receiver from protect mode ?
