Question about Whirlwind FH-778 Air Conditioner
HEAT PUMP WANT HEAT
ICE AROUND THE OUTSIDE UNIT AND WANT HEAT
damaynard
    Problem Solver:
  • 6 Answers
Defrost cycle may be faulty. They are usually simple timers with contacts that change the reversing valve. check to see if the RV is switching
Posted on Apr 21, 2014
1 Related Answer
Anonymous
SOURCE: the unit outside is getting ice around the line close to where you put refrigerant in. House not as cool as needed.
Freon is low. Sounds counter-intuitive, but the large return line should be cool( even have condensation on it) but never cold enough to freeze.Either use factory pressure settings or add just enough Freon until Ice melts. If unit has a high-side sight glass there should be no bubbles present. Do not overfill.
Posted on May 29, 2009
ICEING OVER AT THE OUTSIDE
check indoor coil before that can happen unless it's a heat pump it should also be iced up.
Jan 06, 2014 | Goodman Heating & Cooling
My Grand Aire heat pump is forming ice all around the outside fan unit... Is this normal?
No that is not normal. Your AC unit may be low on refrigerant coolant and needs to be recharged. If it's low, there's probably a leak, which is causing the ices on the outside unit. Contact a qualified service technician to check & service the unit.
Feb 17, 2011 | Heating & Cooling
Ice all around outside unit
if heat pump defroste sensoe or defrost board not working in heat mode if in cooling filter jam strap worn bad gas charge
Dec 13, 2010 | Heating & Cooling
Heat pump gets ice covered when heat is on. Cooling works fine. There is two brown wires coming from the unite in the attic to the outside unite. One of the wires has come loose from the outside unit. I...
Hello,KY the defrost function is not working.The wire goes to frost sensor or the outside unit control.It is LOW voltage wire.Turn the unit off and carefully look for a abandond/bare wire.Maybe a single wire with a wire nut/cap or splice.Reconnect the wire as there should be no EXTRA wires.The unit will make a strange noise when restarted.Good luck.
Apr 23, 2010 | Heating & Cooling
Carrier 38CKC042300. oUTSIDE UNIT FAN WAS TURNING REAL SLOW. ac UNIT IS OFF BUT FAN TO OUTSIDE UNIT IS STILL TURNING. sHOULD NOT BE TURNING AT ALL WITH AC UNIT OFF
The outside fan may run if the unit is in defrost mode this is normal for most heat pumps it is there way of trying to keep the outside unit from staying iced over so the next time the unit runs it will have air flow through the coil and the ice will not be there to prevent air flow.
Jan 12, 2010 | Carrier 38CKC042 Air Conditioner
Our janitrol heat pump is freezing. there is considerable buildup of ice inside the pump itself on the coil. the fan still spins and still heats the interior of the home
Switch the thermostat from heat to Aux. or emergency heat till the outside unit thaws out. This will shorten the life of the outside unit considerable running it all iced up.
Jan 10, 2010 | Heating & Cooling
I have a 20 year old Trane heat pump. Outside
Yes, you will want to put the unit into cooling mode to help assistance with the ice melt.
If you can, block off the outdoor coil or disconnect the outdoor fan motor. This will assist in raising the discharge pressure and temperature and thus, it will melt the ice quicker.
Or, if you have the capability, you can take a garden hose around to the unit hooked into hot water and melt the ice that way.
If your control board is messed up, why aren't you replacing it?
Jan 10, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heat Pump Not Performing up to par...
This sounds like a small freon leak. If you have a low pressure cut out switch, it should cut the compressor off before it gets too low. If you have a lot of ice on the outside coil, then maybe the defrost board or the sensor has went bad. But because you said it is running continuously, I think its low on freon. Unless you own a set of gauges for this equipment, call a pro.
Dec 28, 2007 | Heating & Cooling
Intertherm heat pump
FIRST YOUR OUTSIDE UNIT PROVIDES HEAT BY USING A REVERSING VALVE TO CHANGE THE REFRIGERANT FLOW.THERE IS NO HEAT STRIPS OUTSIDE SECOND YOUR EMERGENCY HEAT TURNS ON ELECTRIC ELEMENTS INSIDE YOUR AIRHANDLER UNIT.IT SOUNDS LIKE SOMEONE HAS WIRED YOUR UNIT WRONG OR HAS THE THERMOSTAT SET IMPROPERLY.WHEN THE HEAT PUMP CANNOT SATTISFY THE SETPOINT THE THERMOSTAT IS SUPPOSED TO TURN ON YOUR ELEC. HEAT UNTILL THE LOAD HAS BEEN REACHED AND THE HEAT PUMP CAN CONTINUE TO MAINTAIN IT.
Nov 28, 2007 | Heating & Cooling
Heating & Cooling Logo
32 people viewed this question
Top Whirlwind Heating & Cooling Experts
Dennis Boxerman
jdthefixer
Paul Carew
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
