When I switch the camcorder on the screen is blurry and so is the pictures and video when taken is there a way to reset the camera as it seams the focus is jammed
SOURCE: Unable to focus camera.
The common cause of lines across the picture is a stuck shutter. This will cause over exposed pictures, out of focus, with lines across them. If the problem is infact a stuck shutter it will require full disassembly to fix, which will be somewhere between $100 and $200 to fix depending on where you send it. An image sensor failure, or focus motor failure can also cause simular problems - but they also cost simular amounts to fix. David Millier Advance Camera Repair
SOURCE: pictures are blurry blue/white colour with vertical lines
You camera has problem with CCD Imager.
Following Sony Official weblink might help you to get Free of Cost repair of DSC-T1 camera with problem in CCD Imager.
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
SOURCE: A95 Canon LCD moniter
Canon will resolve this problem free of cost as per announced Canon CCD Advisory.
Your
Canon A95 has problem with CCD Imager and this part will be replaced by
Canon Support free of cost. Click above said web link to get details.
Have a nice day.
SOURCE: camera fell on floor, now pictures out of focus
That's because the internal focus servomotors are out of place and can't turn the focus ring. I'm sorry but these components are located inside the lens assembly and this is not by any means an user serviceable part. It's composed of tiny servomotors, small coils and plastic parts that can get out of possition or decalibrated if the lens assembly gets opened.
A thing to try would be to hold the camera with it's lens barrel opened in one hand and hit it (gently yet still firmly) against the other hand. There are some small chances that this will bring the internal focus ring to it's former alligment. Other then this, only a service center can fix the camera, but it could turn out to be an expensive repair.
I'm sorry for having to bring the bad news.
Bogdan
