Question about Nokia 6600 Cell Phones
Call barring password blocked
I need my barring password to block CALLER , HOW CAN i DO THIS IF i HAVE LOST THE PASSWORD
5 Related Answers
Anonymous
  • 12 Answers
SOURCE: Blocking Calls
No, actually, there is no way of blocking text messages, just incoming calls. Cheers
Posted on Sep 05, 2007
Anonymous
SOURCE: I want to un-block a previously blocked caller on
go to menu, then select settings icon. Scroll to call settings(option 7). Select all calls. go to auto block(option 2). select off, then highlight word Block. Press the OK button on phone to bring up list of numbers that are blocked. highlight the number to unblock, press option and select delete. this will unblock the number and allow them to call you again.
Posted on Jun 15, 2009
Anonymous
  • 67 Answers
SOURCE: Hi My mobile call barring password blocked.How can I unblock it
if you forget the pass,then you must format your phone by : 1. Backup your data in your phone first. 2. Make sure your battery is fully charged. 3. In off condition, keep holding " * "," 3 ", and "Green/Call" button and turn it on. remember to keep the three buttons pressed until the "Formatting" screen show up. the security code on your phone will be reseted to default "12345",along with factory default. that's mean, remove your call baring too. sorry, this is the only way i know. maybe other experts know the better way? just use this method as your last resort :) regards
Posted on Jan 22, 2010
caroldon
  • 17130 Answers
SOURCE: my nokia 2700 call barring
Please find the following link to be useful .
click on: Nokia support.
Posted on Dec 31, 2010
anupam19
Anupam Datta
  • 263 Answers
SOURCE: i want to block one number. i don't know how to
You need to contact with your service provider or mobile service operator.They will surely help you
Posted on Feb 23, 2011
Have accidentally barred a number, how do I undo it?
On a mobile or land line?
If on a mobile, normally it is associated with the recipient in your contact list. May also depend on your type of phone android or ios (iphone)
check there contact details in your phone then there is normally further options in there profile, like add to favourites, or list and block / un-block caller.!
On a landline would be simuler in the phone history of callers - block / un-block caller / number.
Sometimes it is with the landline exchange sysytem, then call the operator.
hope this helps :•)
Apr 08, 2017 | Cars & Trucks
Tip
How do I Block a Caller on my Android Phone
<p>Here we discuss how an Android phone callers to block. These steps can be useful where you want unwanted calls directly instead of manually reject the call blocking. Follow these simple steps to block a caller making a call to the phone. Please note that the various steps may be other manufacturers like Samsung and Sony Ericsson and HTC. But the base should be almost identical. <br /> <p><br /> <p>Option 1 Steps <br /> <p>1. On the All Apps menu, click Blocked callers<br /> <p><br /> <p><span> </span>2. Click Add caller.<br /> <p><br /> <p><span> </span>3. Select from people (which are your on phone book) or just add the caller (if you remember the number).<br /> <p><br /> <p><span> </span>4. If you like people, click Save to finish.<br /> <p><br /> <p>5. If you add the caller number, click ok to finish.<br /> <p><br /> <p>Option 2 Steps <br /> <p><span> </span>1. All applications menu, click Find People. <br /> <p><br /> <p><span> </span>2. Select the caller wishes to block. <br /> <p><br /> <p><span> </span>3. Calling on the Block, "switching to. <br /> <p><br /> <p><span> </span>4. Click OK to close the. <br /> <p><br /> <p>This "Blocked Caller" function can be disabled, as shown <br /> <p><span> </span>1. All applications menu, click people blocked. <br /> <p><br /> <p><span> </span>2. Select the caller that you want to release. <br /> <p><br /> <p><span> </span>3. About Block caller, change On Off. <br /> <p><br /> <p><span> </span>4. Click OK to close. <br />
on Aug 18, 2011 | Google Android
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
Blocking a caller
you should be able to block callers in your settings menu or in your phone book
Mar 27, 2012 | Samsung Cell Phones
Call barring password nokia 2300 in airtel
The call barring password for airtel is 0000 by default unless you change it. But the call barring feature is not working well with most sim cards of airtel. And the Airtel customer care is not helping us anyway and they try to tell us that its a feature of your cell phone.
If the default password is not working you may alternatively try by setting the "
SEND MY CALLER ID" feature to "No" and this will prevent from making outgoing call. And to block any incoming call use the Blacklist option in your 2300
Dec 26, 2010 | Nokia 2300 Cellular Phone
I need to block a caller how do i do it?
there is NO selective call barring in nokia cellphones. once you try to bar, you cannot receive all incoming calls and text massages. if you again open your cellphone from a barring service, you cannot retrieve text messages.
Nov 01, 2010 | Nokia 6600
I need to block a number from calling me (on my sanyo katana) is there a setting in my phone or do i have to call my provider?
Hi, on this make and model it is not possible to set up call barring the phone has not got the software to do this, some newer phones can offer this feature but most dont.
the only chance you have got of getting a number barred is by calling your service provider and tell them you keep getting nuisance calls from the number you want banned and tell them to block all calls from this person.
as your phone does not have the software for call barring then this is the only way of blocking a number, you need to call your service provider as they can block it for you, but you need to tell them its a nuisance caller and you want them barred from calling your number.
hope that is some help to you
Aug 16, 2010 | Sanyo Katana® II Cellular Phone
Hi My mobile call barring password blocked.How can I unblock it Nokia 6110
Jan 19, 2010 | Nokia 6600
Incoming call number barring
hyperlink.gifI have been told this not possible on nokia 6300 without buying a package which I don't need as I will just ignore call from this particular caller.
Thanks any way for your help.
Regards,
Peter.
Sep 28, 2008 | Nokia 6300 Cellular Phone
Cell Phones Logo
Top Nokia Cell Phones Experts
Resolution IT Dubai
Resolution IT Dubai
matt
matt
aliasger yq
