Question about Philips Televison & Video
Philips DTR 200/05 Freeview box
The green light is on, but it isn't responding to the remote.
No menu will come up .... nothing.
I've checked the batteries in the remote and they're ok.
I've turned the whole lot off at the socket and back on, still no joy!
HELP.
    Top Expert:
  • Philips Master
  • 54,945 Answers
Could be box power supply failure
Posted on Oct 21, 2017
6ya staff
SOURCE:
Anonymous
  • 2985 Answers
SOURCE: freeview receiver
This aeems to be a dud device return to seller or Philips
Posted on Jan 16, 2008
Anonymous
SOURCE: TEAC dvb420 set top box
Sorry guys, have checked on other forums and unless it is still under warranty, or you are good with electronics, it is not worth fixing. Apparently it is a problem with the chip and capacitors on the board. I opened up my STB after fining this out and found heat stress marks all around the chip. Result : Its dead!
Posted on May 14, 2008
Ekse
  • 13434 Answers
SOURCE: freeview probs
can you try a external antenna on it?
Posted on Jun 19, 2008
Anonymous
SOURCE: sagem pvr 6200T UK freeview box, display frozen.
I left the box and went for a walk!!!
About four hours after having freezed an error 09 message came up on the set top display and then everything returned to normal, after an on TV screen message that update had been successful.!?!
No difference in in any operation of the freeview box.
Note to self and other users
DO NOT PRESS OK WHEN ASKED TO UPDATE SET TOP BOX.
Updating the channel tuning does seem to work ok, though I have to vary between where channel 4 can be found - or learn welsh!
Posted on Jul 25, 2008
dmsmith26
SOURCE: just installed new tvonics250 freeview + box
I have one of these boxes and one of the things which has caught me out a couple of times is that the remote can control three devices. To turn the Z250 on and off you may need to press the DTR button at the top of the remote first. When you press the on/off button on the remote the DTR button should light up red to let you know the signal is being sent to the Z250.
You are probably aware of this but just in case you weren't
Posted on Jul 05, 2009
I can't get my freeview box (Philips DTR 2010 to work. Had it working in my flat earlier today & have brought it home for wkend where it's wrkd before. All plugged in but the TV stays 'snowy' when I...
Select the AV input manually via the TV remote. The scart lead may not be switching the TV automatically (if you have two scarts on the Freeview box, then try the other scart socket).
Feb 18, 2011 | Televison & Video
Thomson dti6300-16 won't record freeview channels....
maybe a defragged hard drive follow this procedure:
1. Select Menu, Set-Up, Help.
2. Press the Green button on the remote control.
3. This shows the Advanced Information screen.
4. Now press the Blue button which will prompt you with a warning box.
5. Now press the Green button if you wish to proceed.
6. The DTR will take around a minute to complete the reformat, and will then automatically restart itself.
Next do a channel rescan.
Oct 02, 2009 | Arris DCT2608
Retuning Philips DTR 1500 digibox
Had same problem. Remedy is to put digibox back to factory reset. Dis-connect from mains. Keep pressing + button on front panel as you re-connect to mains. Red LED will be on, when orange LED blinks release + button. briefly press + button. You have solid red LED and blinking red LED. Enter code 9 9 0 0, by remote blinking LED will show green. Wait a few minutes and the instalation page will appear on screen. Go to update and start as you did before and C5 should be installed. Hope that helps.
Dave
Sep 30, 2009 | Philips Televison & Video
My thomson dti 6300 250gb free view box wont turn on
Emailed Topuptv and got this reply
Dear Sir/Madam,
Thank you for contacting Top Up TV.
Please note that we are currently aware of an issue affecting some Thomson DTi6300 boxes.
If your DTR will not come out of standby and is not responding to your remote control, please try the following procedures.
Step 1: Power cycle
First of all, remove the power to the box and wait 20 seconds before restoring power.
Wait while the box tries to restart and allow 2 -3 minutes for this to complete.
Try this at least twice.
If it doesn't go to the solid green light then proceed to the next step.
Step 2: Front Panel Reset
Note: This procedure will unfortunately cause you to lose all of the recordings that you have stored on the box. You will need to be able access the back of the DTR and the front panel buttons
1. Remove power to the unit by removing the power cable from the back of the DTR.
2. Wait 20 seconds and restore the power cable while holding in the standby/power on button on the front panel of the DTR.
3. Release the standby button immediately you see a light 'blip' on the DTR front display and then immediately press the following front panel arrow buttons in sequence Up>Down>Left>Right
4.The DTR will now show the Orange LED with the Green LED flashing until the format has been completed in about 60 seconds. The DTR will return to ON automatically.
5. If requested, perform a channel scan to complete the operation.
We apologise for any inconvenience caused. Our Customer Services department can also be contacted on 08444 159 159. However, please note that we are currently experiencing high call volumes and so may not be able to answer your call as quickly as we would like.
Kind Regards,
Richard
May 04, 2009 | Televison & Video
I have a Thomson DTI6300-16 freeview box. I'm
This could solve problem
Mar 05, 2009 | Arris DCT2608
Just installed new tvonics250 freeview + box
Mar 02, 2009 | TVonics Televison & Video
Remote handset codes
www.remotecodelist.com ..........................................T.
Mar 20, 2008 | Televison & Video
Philips freeview box DTR 220
Same problem with Channel 71 CBeebies. Tried rescanning which worked initially for a few weeks but it's back and rescanning does not fix the problem now.
Feb 14, 2008 | Televison & Video
Televison & Video Logo
272 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
