Unbranded tv/dvd/mp3 etc player 10.4 " tft
6 months old. First I R remote failed. Tested sender on digital camera, seems o k. Then control buttons and on/off switches stopped working. Much random pressing of switch/button combinations starts dvd if disc in. Set then works on av and dvd. Sometimes a sort of menu appears:
F MARIA VER :
01/17/07     15:35:50
VCOMDC   160
VCOMAC   160
Volume goes to max when working.
Help!!!
Philip
Posted by Edward1942 on
5 Related Answers
Anonymous
SOURCE: Power Outage - now DVD will not play through AV
I am having the same issue with mine. I even set everythign back to factory defaults and it still wil not work. Isn't there any tech support palced to find help? See post by Scriptster. Thanks
Posted on Oct 11, 2006
Benimur
Louie Role
  • 6966 Answers
SOURCE: RE; Remote control TV/AV button doesn't work LXI series
Hi, Based on your post/description: 1. the TV is stuck to A/V; 2. you have two video sources - VHS & DVD (assuming both are external and both have A/V outputs with the VCR also with inputs); 3. you want to use either VHS & DVD, one at a time. You can do it the old fashion way, remove yellow, red, white RCA connectors from DVD and plug them at the outputs of the VHS when you want to use the VCR; or Connect the A/V outputs of the DVD to the inputs of the VCR, connect the outputs of the VCR to the A/V inputs of the LXI TV. Hopes this give you an idea. Post back how things are or should you need further information. Good luck and kind regards.
Posted on Aug 24, 2007
Anonymous
SOURCE: SYLVANIA SRCD227 REMOTE CODE
First tell me what brand tv and date of mfg & model# maybe I can help. Chuck [email protected]
Posted on Oct 08, 2007
Anonymous
  • 22 Answers
SOURCE: Can't access AV Channel on Sony KV-C27TD
If the TV has no RCA inputs, then there is no "AV channel" option for it on any remote, just channel selection.
The purpose of a RCA to SCART converter (aka RF modulator) is to convert one of your channels to an A/V input. They operate (standard) on either channel 3 or 4 as selected by a switch on the converter.
If your converter is unpowered, it's entirely possible that the signal coming out is not good enough to overpower your antenna signal. In this case, you may need a powered unit (such as this one http://www.bestbuy.com/site/olspage.jsp?skuId=5806345&productCategoryId=abcat0107025&type=product&tab=7&id=1067388827858#productdetail) which can actively "shut off" the antenna input when signal is received from the auxiliary device.
Posted on Nov 13, 2007
Mike McWhinney
  • 537 Answers
SOURCE: dvd player comes up with pre-stop or invalid key
I would just return it to where you bought it and exchange for working unit. You probably just got a lemon.
Mike
Posted on Dec 14, 2007
I have a Craig portable DVD/CD player. It stopped playing sound. What's wrong? Not on mute.
Craig 9-Inch TFT Swivel Portable DVD/CD Player with Remote
www.amazon.com/Craig-9...Portable.../B007S71NHM
Amazon.com, Inc.
Rating: 3.3 - ‎58 reviews
Amazon.com: Craig 9-Inch TFT Swivel Portable DVD/CD Player with Remote, Black ... But keep in mind this player does not provide the highest quality in portable DVD players one can find. .... The remote stopped working within a few weeks.
Craig 10" LCD Portable DVD Player with Swivel Screen and ...
www.qvc.com/Craig-10-LCD-Portable-DVD-Player-with-Swivel-Sc...
QVCThis 10" portable DVD player from Craig comes with everything you need to help keep ... Plays DVD, CD, CD-R/-RW, JPEG; 10.1" diagonal TFT display; swivel screen design..... Couldn't start DVD unless I held down the door or it would stop.
Craig CTFT716N 7" TFT Swivel Screen Portable DVD/CD ...
www.walmart.com/.../Craig...Portable-DVD-CD-Player.../33846...
Walmart
Rating: 3.5 - ‎18 votes - ‎$59.78 - ‎In stock
Buy Craig CTFT716N 7" TFT Swivel Screen Portable DVD/CD Player with Remote Control at ... I had one of these portable dvd players but paid over $100.00.
Dec 28, 2015 | Craig Televison & Video
Hi there I am having one heck of a time trying to find the codes to program our universal remote to our tv, dvd player etc. Can you please help us.
------------------------------turn ON your tv ,dvd, and any other components you have thee:
------------------------------1. From the remote control universal, set your TV first, press and hold the TV--------------------------------------button and you will see the led light stays ON constantly and then look at the brand of your TV with corresponding codes. then
-----------------------------press these numbers. If the led light of the remote control starts blinking.... therefore you have selected the right codes. Do this one by one entering each codes until you have finally selected the right one.
------------------------------sames process with the other components you have there like your DVD etc.
Jan 16, 2011 | Audio Players & Recorders
Does this tv have a digital tuner or will I need a converter box?
Coby tf-dvd1540 tv
No ATSC tuner in this TV. You will need a converter.
Product Features
  • 15-inch flat-panel TFT LCD TV with built-in side-loading DVD player
  • Standard 4:3 aspect ratio, native 1,024 x 768 resolution
  • Plays DVD, CD and recordable MP3 music CD-R/CD-RW
  • Built-in NTSC TV tuner lets you switch between DVD and terrestrial broadcast viewing
  • Stereo speakers with 3 watts per channel; includes full-function remote control; onscreen display simplifies setup and operation
Technical Details
  • Brand Name: Coby
  • Model: TFDVD-1540
  • Display Technology: TFT active matrix
  • Display Size: 15 inches
  • Image Aspect Ratio: 4:3
  • is_hdtv_compatible: N
  • speakers_included_description: 2 speakers
May 13, 2009 | Coby TF-DVD1540 15 in. TV/DVD Combo
I need the region dvd code for my panasonic triple play tv
1. Press the Menu button on your remote control 2. Press the 5 button on your remote control
3. Press the 7 button on your remote control
4. Press the 5 button on your remote control
5. Press the 3 button on your remote control
6. Press the 8 button on your remote control
7. The currently selected region will be indicated on the TV.
8. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 9 button for multi-region playback
9. Press the Menu button on your remote control
10. Press the Menu button on your remote control
Tested with Region 1 DVD's on my UK player (Region 2 bought from Comet)
Nov 11, 2008 | Panasonic PV-DM2792 Triple Play 27 in....
Openning region 2 on apex DVD player AD 1110W
Nov 10, 2008 | Apex Digital AD-1110W DVD Player
Code for memorex dvd player but using remote from direct tv
Nov 09, 2008 | Memorex Televison & Video
Unlock region codes for portable dvd player - panasonic DVD LS80
Aug 04, 2008 | Car Audio & Video
Locked dvd
Mar 02, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
Dvd recorder region codes
Jan 28, 2008 | Apex Digital AD-1110W DVD Player
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
