Ovens Logo
R
Roland Kroon Posted on Jan 07, 2014
Kenmore electric oven bottom element not working
Removed bottom element and checked for continuity and is ok but bottom element will not heat at all. Model is c970. Oven has digital control panel and shows it cycling between bottom and top elements as expected.
  • Roland Kroon
    Roland Kroon Jan 07, 2014
    edit, i
  • Roland Kroon
    GKM, thank you, I will check this today. Assuming I will need to remove the rear cover to gain access to this thermostat? Is it located near the control panel or do the element wires connect to it. Can you advise what this thermostat unit looks like? Much appreciated for any details you can offer.
G.k. Mahendran
Level 1:
Problem Solver:
  • Contributor 20 Answers
  • Posted on Jan 07, 2014
G.k. Mahendran
Contributor
Level 1:
Problem Solver:
Answers
20
Questions
0
Helped
3731
Points
24
Check thermostate control sensor its locate behind the heating element. check continuty .if its fail .replaced correct value.
GKM
  • Roland Kroon
    Roland Kroon Jan 08, 2014
    there is no thermostat control sensor behind the heating element. the wires run straight to the main circuit board. I fear I will need a new circuit board or may just get another (non-Kenmore) oven depending on the cost of the board. thanks for your suggestion. though.
Oven elements aren't heating, Kenmore Range C970-655821
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Broiler won't work
the broil element
Kenmore electric oven will not bake
The bake element
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Kenmore md3 both elements stopped working at same time
the broil element
The bake element
Replaced oven element still not heating up
The bake element
Surface burners
are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.
You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals.
On modern electronic control ranges, the oven temperature sensor
is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test.
The infinite switch
on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons.
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
Kenmore electric range oven baking element does not go on eveything else works
The bake element
Oven won't heat past 200 degrees
Unplug the range.
Remove the oven racks.
Remove the screws on the bake element.
Carefully pull the bake element out.
Remove the wires from the element.
Use a volt meter set for ohms/continuity and touch one meter lead to one element terminal and the other lead to the other element terminal.
No reading is a bad element/
If you get a reading your oven control is bad.
3helpful
2answers
Kenmore electric range - oven temp low and takes forever to heat
if lower element tests open with continuity meter then it for sure is bad. i would also check the wire ends that connect to the element and/or the control board, they could have loosened allowing a bad connection and low voltage to elementor burnt off.. most ovens do not use the broil element at all during the bake cycle, only during the broil cycle.. some however do utilize the broil element during baking, but at a lower wattage or something..
best of luck,
ttfn
1helpful
Oven not working
you would have to check the element for continuity. Also the oven sensor could be suspect and should ohm out at 1180 at room temp. if both those are ok then main control is probable. without schematic it would be hard to say for sure..there may even be a safety fuse blown.
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
