About 5 seconds for the first.......
there are 2 different ways to delete an App:
1) t's easy to delete apps from the iPhone or iPad. Simply tap and hold on any icon, see them to start to wiggle and tap the red X button in the left corner.
2) For devices running iOS 5 and later, there is also another way to do this is hidden in the Settings app, in the General tab, under Usage.
- you can manage the apps on your iOS device. Once there, you'll notice (after a small delay if you have a lot of apps) that your on-board apps are listed in descending size order. In other words, the apps that take up a lot of space will be listed first.
Tap on any app and you'll get even more info, including the version, the size of the app, all associated media, and the size of the Documents & Data. Just below that, you'll have a Delete App button in "danger" red. At the very bottom, you'll see how much space is available on the device itself.
Deleting apps that take up too much space can be helpful when you're trying to install new apps, of course. You may even notice apps that have a lot of storage attached to them that you weren't even aware of, like internet radio apps that sync songs to your device to play during the time you're not connected to the internet.
SOURCE: How to delete apps on an ipad
To remove/delete an app from your iPad, do the following:
Note: The deleted app will remain in your purchase history in the event that you ever want to re-install it.
SOURCE: Want to delete apps on ipad
On the app you want to delete hold it down until the apps starts shaking and a cross will appear in the apps you can delete. Click on the cross and it will say delete "name of app", then select the delete button. Once you have done this, press the home button to go back to normal. Hope this helps.
