Milk steamer/frother not working. Steam wand has been soaked and there is no dried milk residue.
SOURCE: Leaking water from steamer
For the grouphead check the basket there might be a slight bump around the edge that is preventing it from making a good seal when it contacts the gasket in the head. If the Double works fine then the gasket is not the problem.
For the steam wand try flushing wand for 3 seconds just before steaming, if that does not help with the watery milk, then the boiler is not getting hot enough to produce steam.
SOURCE: Francis francis milk steamer not operating
Check the end/nozzle of the steam wand, if you open the wand and while getting nothing it is hot, then the nozzle is blocked use a paperclip to clear the hole at the end of tip. If you have done this already and still no steam then it is clogged where the steam valve connects to the boiler.
SOURCE: The milk steamer has stopped working
Straighten a paperclip and stick it into the steamer wand. You probably have dried milk gunk in the nozzle. After you've cleared it and it's working again, be sure to blow a puff of steam out after each use to clear collected milk in the nozzle.
