Question about ASUS KGPE-D16 AMD Opteron Server Bd (KGPED16ASMB4IKVM)
No sound from ASUS D2X sound card
I can't get sound from my ASUS D2X sound card when installed on an ASUS KGPE-D16 motherboard. The drivers show as installed and the "this device is working properly" message in the W7x64 device manager shows up. However when I try to run the speaker test in the ASUS audio center the test hangs on the first (R-front) speaker. IO range: B800-F8FF, Interupt: 24 (32). Installed driver version is....7.12.8.1794 W7. OS is W7x64, 32G 1600 Kingston, EVGA 780 video, AMD 6328x2. The D2X worked fine in my other PC.
    Novelist:
  • 170 Answers
Try updating the firmware and then look for a more up to date driver
Posted on Jan 07, 2014
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 1027 Answers
SOURCE: upgrading from amd 3500+ cpu to 3800 duo
2 short beeps is memory parity error. Does the motheboard support dual core? Did you buy the correct socket type processor to match the mb?
Posted on Feb 20, 2010
rsxhawk
  • 8 Answers
SOURCE: Recurring issue: KGPE-D16 opteron 2-CPU "USB
If its forcing a shutdown of the entire machine, I think it may be protecting itself from a voltage issue. What do you have plugged into your USB ports? It sounds like it has detected a voltage problem coming from one of the devices connected to one of its USB ports or something near it and to ensure that the motherboard doesn't get fried its shutting the computer down.
The message is telling you that its detected a device that is over the allowable amount of electrical current and is protecting itself from electrical failure. It could be a problem with the USB jumpers on the motherboard that connect the front usb ports. You might try unplugging these connectors and try to boot up the machine. Leave them unplugged and boot up the machine, if you still get the error after that, it may be a grounding issue with the motherboard mounts that anchor the motherboard to your computer case. If you have any extra mounts underneath the board that you aren't actually using but are coming in contact with the board, you may have to remove them, which would probably involve removing the motherboard from the case.
Posted on Mar 08, 2011
bronk50
Brian Sullivan
  • 27725 Answers
SOURCE: PCI bus 4, device 0, function 0 missing driver
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download them
rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
they will automatically search for and find the correct driver
also at cnet
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name sound drivers
you might have to try a few times to get it right
http://download.cnet.com/drivermax/3000-18513_4-10572602.html
Windows 2000/XP/Vista/7/8 free driver program
http://download.cnet.com/drivers-for-free/3000-18512_4-75548155.html
Windows XP/2003/Vista/Server 2008/7/8 free drivers
http://www.innovative-sol.com/drivermax/
free program, paid update available
hope it helps
Posted on Jul 15, 2012
leehumphreys
Lee Humphreys
  • 38 Answers
SOURCE: ASUS P8Z77-VLK Intel Z77 Motherboard - P8z77vlk usb dirver won't install correctly
After you have run the installer, restart again. It's hardware software, mobo driver.
Posted on Aug 25, 2012
Feb 13, 2011 | ASUS KGPED16 AMD Opteron Server Bd
Onboard sound card not working (ASUS A7S333). I had a pci sound card and removed it to go back to the onboard sound.
You have to refresh your system by deleting the old sound card driver in the control panel or add/remove programs . Then restart the pc to detect the old onboard sound card driver. Then install the onboard sound card driver using the supported motherboard cd driver.
Feb 12, 2010 | ASUS A7S333 Motherboard
Garbled sound as the system accesses something. Disk light pops up at same frequency as garbled sound appears. The Windows startup and shut down sound also is garbled. Using Windows XP on an ASUS K8V...
1. check the cable to the DVD or CD to the sound card it may not be connected properly.
2. remove the sound card from the motherboard and do "shutdown" then restart without the sound card.
3. Shutdown again reinstall the sound card and reinstall the drivers for the sound card.
4. check the the manufacturer website for any firmware upgrade drivers
Sep 21, 2009 | ASUS Computers & Internet
Sound card dosen't work (it is soundmax)
you can get this driver. You might have to look a bit for it. The driver will come from Microsoft though, not from Asus. I have several ASUS motherboards running windows 7. In most cases if you go to the devide manager, right click the "missing driver" for HD audio, Windows 7 has usually gone out downloaded the file by itself. But if you have to look for it, go to the microsoft website and search for HD audio in their downloads section.
Jul 14, 2009 | ASUS M2V-MX Motherboard
I not getting sound from my computer,I want to install M2V-MXSE ASUS. can u plz tell me where these sound drivers are available.......
either from the asus website, http://usa.asus.com/index.aspx ,or from Realtec, that is the hardware that asus normally uses on their motherboard. But just go to the asus site and click on the support and it will ask you the model number of the board that's it. You will see if there are any other downloads that came out for your board also. You should keep that link in your favorites. Here is the exact page for your board just download the driver here. thanks and dont forget to rate my answer, I appreciate it, thanks again,Gym
Dec 22, 2008 | ASUS M2N-MX Motherboard
ASUS KGPE-D16 AMD Opteron Server Bd (KGPED16ASMB4IKVM) Logo
70 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
