Computers & Internet Logo
a
allan suliva Posted on Jan 07, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Asus q200e boot problem
When I start my asus laptop q200e with windows 8 installed I cannot boot to the windows. It go directly to bios menu. Even I restore to default the bios setting I still coming back to the bios menu
pdeluca5
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 109 Answers
  • Posted on Jan 07, 2014
pdeluca5
Expert
Level 2:
New Friend:
Cheetah:
Answers
109
Questions
Helped
16746
Points
114
When you are in the BIOS see if the HDD is present. If not then it's probably the root cause of the problem because the system has nothing configured to boot to.
4 Related Answers
Anonymous
  • Posted on Jan 14, 2008
SOURCE: boot sequence problem
bios satup key
Anonymous
  • Posted on Mar 14, 2009
SOURCE: my asus pc eee 900 does not enter the windows
Go in the BIOS and in Advanced Make you CD-drive the first boot device. Put in your Windows CD and reboot. It wil display. Press any key to boot from CD. Press Enter. You wil come to a screen that ask if you whant to repair. Take that Option. Your Boot sector may be faulty.
Anonymous
  • 29 Answers
  • Posted on Apr 28, 2010
SOURCE: Eeepc 1001HA won't boot.
Take the battery out, leave it unplugged for a day or so... usually resets the bios for me. Sometimes though, you might have to manually unplug the cmos battery as well, that involves opening the system.
maxcarson
max carson
  • 7627 Answers
  • Posted on Nov 30, 2012
SOURCE: My side volume buttons on my laptop ASUS N73SV, also the fn+mute(F10)/volumeup(F12)/volumedown(F11) stopped working after i installed windows 8 pro. It worked fine with windows 7, Tho the fn+F5/F6 for
It's a commom problem when you upgrade to a new OS, Win 8. You have to find the Win 8 drivers. Is that the only thing? In Device Manager, search for hardware changes, locate Win 8 drivers at ASUS website.
Can't seem to get Asus Q200E Tablet to let me do a clean Install of windows 7 from a flash drive is there something I'm forgetting
there should be an area in the bios to change the boot order. In this you will want to put the usb as the first in the boot order.
How to enter bios asus on my asus v550c
On systems with Windows 8 pre-installed, you can access the UEFI (BIOS) setup screens from the Windows 8 boot menu:
  1. Press the Windows key + C, or swipe in from the right edge of the screen to open your Charms.
  2. Click Settings.
  3. Click Change PC Settings.
  4. In PC Settings, select General.
  5. Under Advanced startup, click Restart now. The system will restart and show the Windows 8 boot menu.
  6. In the boot menu, select Troubleshoot.
  7. In the Troubleshoot menu, select Advanced options.
  8. In the Advanced options menu, select UEFI Firmware Settings.
  9. Click Restart to restart the system and enter UEFI (BIOS).
How to access BIOS on an ASUS laptop
Locked keyboard on windows 8 with asus q200
well I know something that might work. don't shoot me if it doesn't.
first of all, make sure you're laptop isn't charging, then take out the batery from the underside. then press on the ON button for about 30 sec. when you've done that you can put the batery back in and start your laptop. your keyboard should be working.... hope it helps :)
ASUS EeePc 1015PEM reboots at windows startup. even with new hdd and fresh install. ok when in bios screen or if i boot into linyx
Which windows OS are you using? windows xp, 7 or 8?
Anyway the problem might be corrupted installation CD. If you install windows on other computer using this CD, so if CD is OK, then
start your laptop and press F8 repeatedly until Windows Advanced Boot Options appears. Then choose automatic restart on system failure. This option will allow you to see Blue Screen Of Death and to understand what causes a problem.
2answers
NEC laptop will not boot from disk or USB
just make sure ISO files or DVD you are using to boot with are actually bootable disc for OS ,as for USB booting ,you will need to turn on usb boot on the bios and software needs to be USB software.
and I am not talking about boot order that you have already selected.
check windows 8 software on anther machine and see if you can boot with it
2answers
HDD problemon asus motherboard p5rd1-vm
You need to install the SATA drivers that belog to your specific motherboard.
When you are installing Windows thru your Windows CD, there is a moment at teh beginning of the process that you will be asked to press F6 if you want to install 3rd party drivers.
That is your call.
Once the SATA drivers are installed, you will be able to continue with your Windows installation.
Don't forget to rate this answer if it helps.
2helpful
Boot failure asus a7v 133 motherboard installed a pci sata raid
Hi whistler1410, you need to enter your bios menu. Press the delete key every couple of seconds to load the bios menu.
Once in the bios (See instructions located at the bottom of the menu, to help you move about).
You should see all connected drives at the main menu.
This includes the SATA writer & hard disk drives.
Go to the bios menu, BOOT.
SATA drive even DVD drives are seen by the bios as a master drive. So within the BOOT menu go to "Boot device priority".
The boot priority should read as follows.
First boot device [Floppy disk drive] (If one is connected)
Second boot device [Your SATA DVD writer]
Third boot device [Your primary hard disk drive] (The drive with windows loaded on it).
If you do not have a floppy disk drive than make the first boot device your DVD writer.
Save the bios & exit the bios. You should not receive "boot disk error message anymore".
Run into a problem, post here.
Good luck whistler1410!
Mike
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
