Question about Sharp LC60LE835U 3D LCD TV
No picture power lite flashes twice slow, then 5 flashes faster
Turning off and then back on goes off after 5 seconds or so then the flashes begin on the power as described
4 Related Answers
Anonymous
  • 33 Answers
SOURCE: Set up only visible for 2 seconds, then black - Aquous lc-37d43u
Unfortunately I can promise you that you CANNOT repair this. Your power and opc lights coming on, but the tv is not coming on. That is a issue within the tv. Give sharp a call and they will have somebody come fix your tv free of charge, if they cant fix it, they will replace it for free. That is the only thing you can do. Sorry bro
Posted on Dec 12, 2008
Anonymous
  • 55 Answers
SOURCE: When I turn the sharp
Probably, the switching supply of your TV cannot sustain power required.Needs to be repaired.
Posted on Aug 23, 2010
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: I am currently working on a Sharp Lc37sb24u. I was
Did you check the service manual troubleshooting guide yet. You can try disconnecting the power to the inverter board and see if it will stay on and have sound.
Service manuals:
http://elektrotanya.com/?q=showresult&what=Sharp%20LC37SB24U&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Oct 27, 2011
Chi Chu
  • 8457 Answers
SOURCE: My Sharp Aquos TV went off whilst we were watching it and won't come back on. The red power light flashes twice per second and the green OCD light flashes three times every second. Is there a re
Tries tv unplug replug the tv back about an hour later,might resetting the tv back factory setting and should work again.Still have the problems,the main board it is shorted and dead require changing.The main board that board were the incoming broadcasting signal wire plug into it.U have some basic machanic skills like take things a parts and putting it back together again.Should have no problems change this board at all..Tried websites like Shopjimmy.com,eBay.com to buy a refurbish main board for the replacement.
Posted on Feb 24, 2013
My 2003 gmc 2500hd. lite came on and said reduced power engine and stop me going about 5 mph. why
you need to scan the computer that has a electronic throttle body and a electronic gas pedal one sensor goes bad and the system goes into limp mode
1helpful
Code number to program my bell remote to this tv
01768,11034,11265, 10178, and 11748.
Or you can:
1. Press "TV" button
2. Hold "P" (program button) till the "TV" button flashes once then twice
3. Enter 9 9 1, and the "TV" should flash twice
4. Aim the remote at the TV and hold the Power button down for at least 3 seconds. (Remote automatically goes to first code but it probably wont work so go on to step 5)
5. Press CH+ repeatedly till the TV shuts off and stop immediately!
6. Hold "P" for 2 seconds
7. Hold "Select" for 2 seconds
8. Hold "P" for 2 seconds
9. Hold Power for 2 seconds and TV should turn back on
Found at:http://wiki.answers.com/Q/What_is_the_universal_remote_code_for_a_haier_tv
Be sure to rate macapplezoo 100% or whatever you think I deserve!
2answers
"on" light flashes twice and then "blacks out"
IF power light comes on and a few seconds later goes off, do the self check this model has.
On front of set when this happens, press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and then release both buttons.
Watch the power light closely, it should blink a two digit error code like; 2 blinks, 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
4helpful
When I turn on the TV the blue indicator light comes on but there is no display, then the blue light starts blinking.
The following steps should be able to correct the problem:
1) Unplug the TV or remove AC power from the TV
2) Count to ten and then plug in the TV
3) Locate the [Menu], [VOL-] and [Power] button on the TV’s side panel
4) Using the buttons on the TV’s Side Panel, press and hold both the [Menu] and [VOL-] buttons.
5) While holding those buttons, press and release the [Power] button one time and count to 3 before releasing the [Menu] and [VOL-] buttons.
6) The TV’s lower left Blue Power LED will come ON.
7) Wait 30 seconds. Confirm that the blue LED on the Lower Left of the TV (not the iPod dock for iPod models) has remained ON during this time.
8) Press the [Mute] button on the TV remote twice
9) Unplug the TV or remove AC power
10) Count to ten and plug the TV in
11) The TV power should automatically come ON and the blue power LED with be ON
12) Wait 40 seconds and the TV picture should appear
13) You can now continue using your TV.
14) If the picture does not appear, power on the TV manually:
· If the LED begins flashing, unplug and power ON a second time.
· If the LED begins flashing again, power ON the TV without unplugging
If the LED begins flashing again, contact us directly by phone to obtain a local authorized service center for you.
If the TV does power on, please reply back with the software version number for us to research this issue. Please follow these steps to obtain the software version number:
1) Press the [Menu] button on the remote control.
2) Using the arrow keys in the center of the remote, scroll over to the "settings" menu and select the [OK] button on the remote
3) Scroll down to "system info" and select [OK] button on the remote
2answers
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
HP md5020n does not have picture
UNPLUG IT AND IFF YOU CAN TAKE THE BACK OFF ,,AND CAREFULLY LOOK ALL IN THERE FOR A FUSE ,,SEE IF ITS BLOWN,,
1helpful
2answers
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
PT-50LC14
Hey Beestergirl, I just had my tv fixed for 385.00
Sharp LC60LE835U 3D LCD TV Logo
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
