SOURCE: Xerox phaser 7760 streaking
to fined out what the problem could be you need to open a word doc and sent a blank page to the printer. from this it will show where the problem is in the printer
if u still get streaking it couls be a faulty toner and it may not be the cyan toner either. i would give the fuser unit in the printer a check. if there marks on tthis unit i can cause this problem as well
SOURCE: Xerox Phaser 7760 Prints White Lines Diagonally Across Page
That is normally caused by a bad developer housing.
SOURCE: Xerox phaser 7760dx
This could possible be the magenta drum cartridge. also try cleaning the ROS assembly window below the drum cartridge.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
SOURCE: i have blocked the fuser uit
All you have to do is open the fuser unit on the end (2 Screws) and you will find a fuse which has 3 strips (in a plastic casing with wires attached). You must the solder the strips so that they are joined, and that should reset the fuser.
SOURCE: Phaser 7760 dirty printing
Dear User,
This is a common problem of all laser printers, don't worry i will give you solutions for this. If you can able to remove the DRUM set from the printer and check that any power leak or not, IF yes clean it well and insert into printer again take a printout , afterthat also coming like dirty. So please change the drum and put a NEW DRUM. Your drum capacity is crosed beyond the limit.
I hope that my suggession will helpful to you, if yes please rate this ...
