What do I need to hook up my wii and how to hook up.
SOURCE: hooking up from hd receiver to hdtv ready
This particular television puts you in a tough bind - you can use Component cables in AV1, but you won't be able to get HD. Or you can use the Component cables in the right-most component slot, but since your HD Receiver probably doesn't have V/H Sync connectors, you may get a rolling picture. Try the component cables in the right-most slot (I'm assuming, perhaps incorrectly, that your actual model # is not really a 50P8341, which has no V/H Sync slot).
-Tha Mp3 Doctor
This particular television puts you in a tough bind - you can use Component cables in AV-1, but you won't be able to get HD. Or you can use the Component cables in the right-most component slot (AV-4), but since your HD Receiver probably doesn't have V/H Sync connectors, you may get a rolling picture. Try the component cables in the right-most slot - if the picture doesn't roll, you're in business.
Once again, I doubt that your model # is a 60pp9202, since that model doesn't have a VGA or DVI slot. If the picture rolls after trying the above, you will need to purchase a HDMI-to-DVI-D cable and hook it up from the HDMI output of your HD receiver to the DVI slot (that looks like a VGA slot) on the back of your Philips or Magnavox.
-Tha Mp3 Doctor
-Tha Mp3 Doctor
