Vehicle Parts & Accessories Logo
P
Paul Scott Posted on Jan 06, 2014
Bolt size for wheel hub on 1999 dodge ram 2500 5.9L
Dan Lester
Level 1:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Jan 07, 2014
Dan Lester
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
0
Helped
5068
Points
22
Could use a little more info on this to be sure on what part you're referencing for sure, but here goes. Hopefully this will cover it for you.
The lug stud is a 9/16 with a 7/8 hex lug nut.
The bolt pattern for wheels is 8x6.5"
The axle to hub nut is 1 3/4"
The bolts holding rotor to spindle are 12 point 14mm
2answers
Front axle to hub nut torque spec on 2004 doge ram 1500 4x4
Here are the specs you're looking for:
• Font axle to hub nut torque 185 ft-lbs
• Front hub bearing bolts 60 ft-lbs
• Caliper housing bolts 125 ft-lbs
• Caliper guide bolts 26 ft-lbs
• front spindle hub nut 97 ft-lbs
• lug nuts 100 ft-lbs.
1helpful
I'm trying to remove the axle nut on my 1999 Dodge Ram 2500. I can't remember if they are left or right hand threads. Any suggestions? I'm working alone on this issue, trying to get to the wheel hub...
sould be standard left to loosen,, make sure you soak it with PB blaster or Kroil,, I've spun the nuts, before(plow trucks) and had to buy the stub shaft(dealer only $$$) and new U joints,, Keep soaking it!!! Hub bearings are pricey also,, good luck,, You will have to use the jaws to pull it off, and the bolts on the back side, soak those,, I ve separated the hubs before, and then i ve had some come off easy,, Good luck,, total fix $350-$1200 per side. keep soaking, is all i'm saying...
1helpful
What size socket for taking of center hub on 2002 dodge ram
YOU HAVE TO GO TO AUTO ZONE OR ADVANCE AUTO PARTS ASK FOR HUB AXLE SOCKET.THEY WILL FIND YOUR SIZE NEED.SOCKET COME DIFFERENT SIZES LIKE 27 METRIC 32 AND 35 METRIC SOCKET.
1helpful
2005 dodge 2wd 3500 front hub assembley.. how do i
there are three mounting bolts behind the wheel studs
remove the bolts
remove abs sensor
slide the hub out of steering knuckle
3helpful
I need a diagram on front hub and brake assembly for 1999 dodge 1 ton dually 2 wheel drive. the front brake rotor is warped i need to replace it
8–Stud Rotor
  1. Raise and support the vehicle.
  2. Remove the wheel.
  3. Remove the hub extension.
  4. Remove the brake caliper assembly.
  5. Remove the axle nut cotter pin. Remove the axle nut.
  6. Disconnect the ABS wheel speed sensor wire from under the hood. Remove the sensor wire from the frame and steering knuckle, if equipped.
  7. Back off the hub/bearing mounting bolts 1/4 inch each. Then tap the bolts with a hammer to loosen the hub/bearing mounting bolts.
  8. Remove the bolts and remove the hub/bearing assembly.
2answers
Remove front rotor on a 1999 dodge 2500 4x4
Take off wheel
remove brake caliper
remove rotor
2helpful
Wheel bearing assembly 2004 dodge ram 1500
Hub & bearing should be one assy, is that what your looking at?
3 bolts behind hub, to remove, done?
1helpful
2answers
How to remove rotors on 97 dodge 2500 4x4
sounds like the rotor is stuck on the hub. Try beating it with a hammer you dont have to take the 4 bolts off they remove the wheel bearing. Axle doesn't have to be touched as well. After you remove the caliper and bracket the rotor should fall off.
HOW DO I REMOVE ANS INSTALL WHEEL HUB 2002 DODGE 1500 PICKUP!WHAT
4x4 has 3 bolts in back of knuckle take them loose and tap on them to force the hub out of the knuckle
1helpful
4answers
2002 dodge ram 4WD front hub bearing
Here is the easiest way . take a 14mm socket and extentsion and place it on the bolts and place againt your axle tube and start your truck and turn your wheel against it instead of pounding you will use your powersteering like a press to get your hub out its quicker and less strenous than pounding on the bolts ive done this many times i even made a extentsion for it i use a 14mm 1/2 drive shallow socket and a extension thats about 4 inches long i know im posting late on this one but if it helps anyone out then great
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
