Please i would like to know how to install a firmware of my konica to make the language franch and to print 1200mm
Self Help Product Support Konica Minolta Business Solutions Inc
try this site
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Printing labels on bizhub C450
Hi nwillett,
Yes and no, sorry if that doesn't make much sense.
For years Minolta recommended Avery labels, but these days they recomment labels manufactured by Howard Smith Papers, their website is http://www.hspg.com/
The thing with labels is always to use the one your copier service company suggests. Otherwise they'll invalidate you contract and you'll be liable for callouts and repairs caused by using Avery labels.
However, Avery labels are good and I have experienced very few problems with them I pressume you using the lables in the correct orientation and also using the manual bypass to feed them.
Regards
Taminol
SOURCE: Konica Minolta C450 status is offline.
Change the status to "Online". Sounds crazy, but most likely you print driver is set to enable "SNMP" on the port settings. Disbale this setting in the print driver, also set print Queue to "LPR" and name the LPR queue as "printer". Make sure there are no jobs int he queue when you change the port settings.
SOURCE: Konica Minolta 1350 printer won't print with Vista
Also try turning spooler OFF/ON. Also, try turning 1350 OFF/ON. Those sometimes work. But 1350 had same problem with W98SE so must be a problem in 1350 software(?). I got so tired of this that I bought a Canon MFC which works perfectly. Still use 1350 to use up the toner.
