Question about Nakamichi Audio Players & Recorders
Comcast Remote Code for Nakamichi Soundbar
I cannot get my Comcast Remote to connect to our Nakamichi NK5 Soundbar. The code "31313" given on the Comcast website does not work. Any suggestions? Thank you! :)
Posted by Melody Raudenbush on
Colin L.Swan
  • 71 Answers
Check out the Comcast web-site for the long list of Q and As - if nothing helps there then click on the technical support 'contact us' icon.
Good luck but be sure to give them every detail even it seems silly.
Posted on Jan 09, 2014
5 Related Answers
Anonymous
  • 50 Answers
SOURCE: Need a code for my Comcast Universal Remote
30176 is the code you need . Press Aux and then hold setup until Aux lights up. Enter code. If you want the remote to control the receiver all the time, press Aux and then hold setup until Aux lights up. Enter 993 then press Aux. Aux will flash, now press Cbl and Aux should light up when you use the volume.
Posted on Jul 06, 2009
robotek
Graeme Ross
  • 1512 Answers
SOURCE: Martantz SR 3000 - Are there any remote codes
Hi, sorry it took so long for me to get back to you. The system does not give us updates on older problems.
Found the manual, and it does have 5 digit codes, Page 2 lists the codes for marantz as 0321, 0269. Hope that helps you.
regards
robotek
Posted on Jul 05, 2008
Anonymous
  • 6 Answers
Click here for Comcast Remotes Five Didgit Codes hope it works for you did for me.
Posted on Sep 10, 2008
greenspan
Remmy Moore
  • 1734 Answers
SOURCE: looking for remote code for sherwood rx4105 to work with comcast
Ask the remote code experts -
They will get it for you.
http://manualfox.com
Posted on Jun 30, 2009
Nomodo4u
Poppy Chulo
  • 863 Answers
SOURCE: Need the remote code for my receiver to program my Comcast remote
Here you go dude:
http://www.comcast.com/MediaLibrary/1/2/CM/VanityURL/documents/comcast_on_demand_remote_manual.pdf
Posted on Oct 25, 2009
Need code to use Nakamichi NK5 with Direct TV remote
use your manual,it would cost money to find out for you,i have answered 3 of your questions.
Oct 17, 2015 | Nakamichi NK5 Soundbar Home Theatre System
I am trying to get a code for my nakamichi NK6 soundbar. I am using a tivo remote and the codes that came with it won't work.
0180,0194,0155 are the common codes to check with Nakamichi devices. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 02, 2015 | Tivo Televison & Video
I need the direct tv remote code for a Nakamichi sound bar nk5
2978,2995.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
Sep 03, 2014 | Televison & Video
RCA RTS736W code for comcast remote
2879,2880. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Mar 13, 2014 | RCA RTS736W Rts736w 30 Wi-fi Streaming...
Nakamichi manuals
WHERE DO I HOOK UP MY SYSTEM NAKAMICHI NK5.
Jan 10, 2014 | Nakamichi New Original SOUNDSPACE11 Remote...
How do I set my comcast cable remote to the Kenwood cs 5.1 receiver?
These codes may work:
Depending on the comcast model remote you have: Some require the full 5 digit code while others only use the last four digits.
Codes for Kenwood receivers:
31313 31571 30027 31007
Most Direct, Comcast and COX remotes use the same basic codes either with or without the first digit which is always a 0,1, 2, or 3. (0 for cable boxes, 1 for TVs, 2 for DVDs, 3 for audio amps and receivers)
Hope this helps.
Jun 05, 2011 | Kenwood VR-507 Receiver
Top Nakamichi Audio Players & Recorders Experts
STEVE
ray gallant
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
