Question about Casio Music
Casio - 120 Turns itself off randomly
When i am or am not playing it it randomly turns off not all the time but sometimes it turns back on fine but i was wondering what could be wrong with it
Posted by ANNIE JACK on
Reuel Teoh
    Champion:
  • Casio Expert
  • 411 Answers
Casio CDP has Auto Power Off: 30 minutes after last key operation, Auto Power Off can be disabled.
Please read the manual.
Posted on Aug 12, 2014
I was wondering if it is normal that my piano down-tunes while I am playing.
No, it's not normal.To determine if it's a setting glitch or a hardware problem, perform a factory reset and see if the problem continues. If it does, it's a hardware problem and needs to go to the shop. Here's the reset instructions-
https://www.youtube.com/watch?v=8Xavte8p3Qc
Nov 16, 2014 | Roland RD-700NX SuperNATURAL Stage Piano
Casio CDP - 120 turns itself off
If it turns itself off while playing, I would try to buy a new AC Adapter to test. DC cable of AC adapters are often broken internally after much "bending".
Jan 06, 2014 | Casio Music
Crate flexwave 120 head effects malfunctioning
That is probably a momentary switch that is dirty and sticking. These onboard effects on guitar amps are usually nothing more than a computer sound card and I've found bad connections going to and from them as well. I do think that switch is dirty and sticking, though.
Feb 19, 2013 | Crate FlexWave FW120H Guitar Amp Head with...
Rhythm accompaniment does not play. Start button flashes 3 green then 1 red. Began when someone randomly pushed number buttons on the key pad.
Do an initialization (factory reset) by holding the HIGHEST WHITE key down and turning on the power. Hold the key for an extended time until display confirms initialization complete. This will restore unit to factory defaults.
Jul 14, 2011 | Yamaha YPG-625 (YPG625) Digital Piano
Well, my Ibanez TBX150R Tone Blaster Xtreme Guitar Combo Amp worked fine for the longest time, and suddenly after a show, every time I turned it on the "hot" channel it popped and banged every...
Sounds like a problem with the channel itself, if the clean channel works then its not the lead, input, guitar or the drivers. You have to be careful when opening up amps as some can hold a residual charge and there can be danger of electrocution.
I would recommend getting it looked at by a pro, it doesn't sound like an expensive fix.
Jun 30, 2011 | Ibanez Tbx150h Tone Blaster Xtreme Guitar...
Static and noise from right side speaker?
interfearence from something in house
May 01, 2010 | Yamaha Portable Keyboard
The pick-up on my Ibanez Gio (brand new) keeps
The problem is likely a switch.
HOWEVER I found one that had intermittent like yours that was caused by a terminal on one of the pots touching the wood inside the cutout where the pots are.
HINT the black paint is purposely conductive as an electrical shield and is tied to ground. It is called "Aqua-Dag"
This can be a frustrating problem due to the intermittent failures that never fail in the shop... The problem is if you are under warranty, you would void the warranty by opening it yourself.
If they can't find anything, see if turning the pots to the ends with a bit of force cause the problem to occur. SOMETIMES the pots MAY turn just a bit so a terminal contacts the paint.
Oct 20, 2009 | Music
CASIO PX575R 1 year old off warranty. Randomly, keyboard will lock up. The keys will stop triggering any sound, but the rhythm machine keeps on playing. And all the controls are locked, not a single button...
This may be a hard one to analyze, however my educated guess is that a static discharge is putting the internal processor in a program loop it shouldn't be in.
It is my experience that you MAY not even feel a discharge even.
Suggest you make sure to not wear static producing clothing as a test. Sliding across a piano bench might even create the discharge.
The unit SHOULD not be sensitive to this, but the designers don't always do things right.
ALSO make sure the unit is plugged into a grounded receptacle.
Use of external things like amps and headphones can WORSEN the problem of static. External amps MUST be fed from the same receptacle.
Aug 07, 2009 | Casio Music
Music Logo
100 people viewed this question
Top Casio Music Experts
Ekse
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Casio Music Expert? Answer questions, earn points and help others
