Question about Retail Supplies
Dear All, I need driver for wincor nixdor beetle /M II Plus, TH230, BA84,80 ? who can help pls. ?
POS equipment, I needs to make this machine worki on windows XP
Posted by Muaweiah on
Dayton Computer
  • 1,578 Answers
You must get the software for XP from the POS manufacturer.
Posted on Jan 28, 2014
How to find POS System for iPad suppliers?
Hi William. You can get POS for ipad but you will limit yourself to only a few as probably 95% of POS is Windows based due to simpler software, cheaper machines and MUCH larger touch screens with more products on them. Also, you have to buy more expensive (and sometimes unreliable connection) wifi or ethernet printers as the ipad has poor connectivity (no sockets to plug devices in). If you are still keen, check what is available in your area on Google using keywords such as POS, ipad and your area. Hope this helps
May 30, 2016 | Retail Supplies
PEA is on the screen and no keys work
stuck splash screen Cash Registers & POS Equipment ...
www.fixya.com > Forum > Tags > stuck splash screen
Ask your stuck splash screen cash register and pos equipment questions. ... ...screen displays PE, machine stops working Register tape won't feed, turning it off then back on ... the register is stuck and is displaying PEA Perfom a master reset ... Screenstuck on x2/z2 turn the key and it stays on x2/z2 no matter key position.
delay stuck Cash Registers & POS Equipment Questions ...
www.fixya.com > Forum > Tags > delay stuck
Cash Registers & POS Equipment delay stuck questions and answers. Ask your delay stuck ... Also if that doesn't work and its a dual com, make sure its set to dial. coppy ... Ad ... the register is stuck and is displaying PEA Perfom a master reset ...Screen stuck on x2/z2 turn the key and it stays on x2/z2 no matter key position.
Hi There my SAM4S is showing PEA on the screen. All the ...
Nov 26, 2015 | Retail Supplies
Pos terminal no connection to printer
Randy, happy to help you brother, first things first!
Okay lets break this down in simple steps! this sounds like simple Networking issues, due to not printing and being able to use the credit cards features.
Is your POS in the same Network range? usually a network consists of 192.168.ZZZ.1 ( Z being a numerical example) all the way to 254. if your other pos is for example to say 192.168.0.80 then this pos has to be ALSO in the same range but with a different IP lets sayyy 192.168.0.81 or which ever is not in use. let me send you a link with the instructions on how to change an IP> https://www.howtogeek.com/howto/19249/how-to-assign-a-static-ip-address-in-xp-vista-or-windows-7/
if your connected to the same network, and you still can't do anything and your ip is correct, then this means that you have another equipment with the same IP as the POS this is called an "IP Conflict" simply change the IP of the adapter and your gonna be good to go.
if everything is perfectly fine, then restart the "Printer Spooler" service within the machine to be able to print and contact the printers. attaching the link aswell http://www.dell.com/learn/us/en/05/videos~en/documents~esupport-start-restart-windows-print-spooler-eng-ver1.aspx
i hope i have been able to help you!
Sep 18, 2017 | Logic Control Computers & Internet
I purchased the equipment from a restaurant going out of business. I have the programming manuals but I CANNOT find anything on how to INSTALL it! PLEASE HELP!
sure, first i need to know the model of your equipment and what you want setup ?, install opering sistem ? install just aplications?, install just drivers etc , i need more informartion about you want to do or you need
Aug 11, 2010 | Microsoft CompuRegister POS-1000 POS...
Dear expert pos machine(ibm SureOne100 Type :
looks like its running on IBM PC DOS. code page 708 - arabic. https://msdn.microsoft.com/en-us/library/cc195061.aspx however if you are using windows, then you may need an arabic windows, just adding an arabic languge file wont help. IBM PC Dos doesnt have an arabic option. you can download the ibm surepos 100 4613 technical reference manual which is what i did for you. but it no help in that arabic is not an option. research using arabic with DOS. because your keyboard is basically a PC one working in DOS.
Oct 03, 2017 | IBM SureMark Printer TF6 Thermal Label
Stack overflow
Now THIS is an old school problem. Way back, memory resident space was assigned to help with IO operations. This error happens when there's not enough memory to complete an operation with a given piece of hardware. I haven't seen this in ages! It has to do with IRQs. I assume you're dealing with a custom legacy application on your POS equipment, or whatever you're using is taking an older approach to getting things done. Here's some information from Microsoft on why the problem happens and how to fix it. Enjoy!
http://support.microsoft.com/kb/145799
Apr 05, 2010 | Microsoft CompuRegister POS-1000 POS...
How do I set the tax for dept 11 and so on?
according to me 1 to 10 dept can be done tax or non tax cant mix it same as so on from 11 to 20 dept either tax or non tax but if u want to mix it then u need to use the software that comes with it ,,,intall on windows xp not working on windows vista then go from there its really easy with software
Oct 11, 2009 | Sharp XE-A404 PC Desktop
Error 75 Path/File Access error
You will have to run the program as the Administrator.
Either Right-Click and select "Run as Administrator", or
Right-click, Properties, Compatibility tab, Privilege Level box, check the "Run this program as Administrator" box. (In Windows 7, don't know if the same for Vista or XP.)
Oct 01, 2009 | Sharp XE-A404 PC Desktop
Is it viata ready or what os do i need for epson tm-u220pb printer
The requirements for epson tm u series printers are.....
Windows XP, Windows 32bit: Microsoft Windows XP Professional 32bit SP3 English, Microsoft Windows XP Embedded 32bit SP2 and Microsoft Windows Vista Ultimate 32bit SP1 English
Windows 64bit: Microsoft Windows Vista Ultimate (x64) SP1, Windows Server 2008 Standard (x64)
Aug 10, 2009 | Epson TM-U220PB Matrix Printer
Run time error 75 path/file access error what
yours operating system files would be courpted so kindly format yours machine with windows xp service pack 2 and then watch the performance.
Jul 18, 2009 | Sharp XE-A404 PC Desktop
Retail Supplies Logo
189 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Marvin
Marvin
Are you a Retail Supply Expert? Answer questions, earn points and help others
