Question about Buck Car Audio & Video
Dekodiranje auto radio philips ccr 2006
Volume suddenly increases automatically to, what sounds like, maximum. Also hear some static clucking sounds. Believe it has also come on automatically overnight and drained battery.
5 Related Answers
Anonymous
  • 81 Answers
SOURCE: UNCONTROLLABLE SURROUND VOLUME
bad solder connections and or dirty controls.
Posted on Dec 15, 2006
Anonymous
SOURCE: FLM 3232 television low volume
I hooked my tv up and there is no sound coming from the tv. I do not have surround sound just the tv. How do I make it work I need volume please
Posted on Jan 15, 2008
mahesh patel
  • 197 Answers
SOURCE: Volume turns itself to maximum
soft waer call phillips
Posted on Jun 07, 2009
Anonymous
  • 34 Answers
SOURCE: my vauxhall vectra has had the battery replaced
the thing with radios is that they are hard to figure out what the code is. Call their free customer service center and give them the model number and serial number and they will be able to walk you step by step on how to enter the code......
For de radio hold the AS button for several seconds You'll get ten attemps to fill in the code. First tap de "1" key as many times to reach the first number of the code. Then tap the "2" key for the second number of the code then the "3" and the "4" Then the AS key for serverl seconds and ready. If you have a CD changer use the "o" key instead of the AS key
YOUR CODE IS 3xx1
Posted on Feb 05, 2010
john h
  • 23438 Answers
SOURCE: Radio Reset for 2006 Hyundai Sonata
doubtful probably burnt up a component in radio thats why when jumping a vehicle u turn off all accessories so when something gets crossed it doesnt short it out usually will blow a couple of fuses
Posted on Feb 10, 2010
What causes audio to suddenly increase to maximum?
Volume in modern systems are controlled by a single IC. If that goes, it makes the volume functions go wonky. The IC can be found by tracing the wires from the volume control, or following the circuit if it is mounted on a PC board.
Jan 29, 2016 | Audio Players & Recorders
Sandstrom
Buy additional speakers. A soundbar is the usual answer
Sep 08, 2014 | Televison & Video
HT-RC180 all of a sudden no sound output (not muted, etc.) Turned it on yesterday, and everything works, but no output. Observations: No static/noise floor when volume is increased to maximum-absolutely...
Hello, I think that I may have responded to you via an email sent to our customer support. If you are not the person that I responded to please email me at [email protected] with your serial number. Thank you, Onkyo USA
Jun 30, 2017 | Onkyo HTRC180
Hello, I have an RT 2870 RCA surround sound system. When I turn it on all I hear is static and its not until I crank the volume up to around 25-30 before I can hear the audio. How would I fix this problem?
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control (volume pot??) may have developed a high-resistance or 'dead' spot through defect or idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
May 24, 2011 | Audio Players & Recorders
The volume ramps to maximum. I can adjust it back
Sounds like the circuit board for the button keys in front has a shorted tactile switch causing sound to keep increasing, Replace all switches on this board or get new board. I believe it is called a HS board or very close to that.
Dec 30, 2009 | Sony FD Trinitron WEGA KV-32FS200 32" TV
Low sound when converter connected
use converter volume button to increase the volume to the maximumthen use the tv remote to increase again up to the maximum. After to increase or decrease use only one remote.
Thank you for voting for me if itworks.
Jul 11, 2009 | Televison & Video
Microphone volume goes down automatically
Go to control panel and select the sound option
There you will find microphone settings that are enabled, one of them is set to on and adjusts volume automatically as the noise increases, jsut disable that option
Cheers
Jul 08, 2009 | HP Pavilion dv6000z Notebook
Volume change, followed by slight static playback.
I believe you have dry joints in output drive it require a qualifier Technician the do this you need special soldering station with anti static you are dealing with surface mount components if you shorted some thing in output drive it could damage to the output they are expensive to replace, now is not too bad you should bring in to Sony or servicce center Sony to repair it
Cheers
Dec 04, 2008 | Sony STR-DB1070 Receiver
Dec 12, 2006 | Technics SA-AX530 Receiver
Car Audio & Video Logo
Top Buck Car Audio & Video Experts
Marvin
Marvin
 Mikey
Mikey
Are you a Buck Car Audio and Video Expert? Answer questions, earn points and help others
