My refrigerator keep 'buzzing' even with the door closed. It stops for a while and then starts again, :). Help... Thank you
SOURCE: Buzzing noise coming from beko fridge freezer
1st thing what relation does sound have with light! i thing you must be clear about the question or the whole process so i can assit you clearly
SOURCE: Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
SOURCE: Express Thaw comes on when refrigerator door is closed
We have a GE Profile side-by-side refrigerator which we purchased in 2002, Model PSS25NGNACC. Today we had a repairman come to investigate why the Express Thaw 3lb. light was on and could not be shut off. If shut off, it came on again when the door was closed and reopened. The repairman called GE and learned that this light was an air filter change indicator which turns on at some interval (2 years, they said, although we don't remember ever seeing this before). The air filter involved is for the interior of the fridge and is not critical. GE said that newer master control boards have this function disabled, since people rarely changed the filter and GE no longer makes them. I have read our user manual cover to cover and find nothing on this filter. I guess we just have to pay the $70 dollars to have someone come and call GE to figure it out. But, enough of that. To reset the indicator, simultaneously press the following keys on the touchpad and hold for 5 seconds until it beeps:
Adjust Freezer Temp (Warmer)
Express Thaw
Adjust Refrigerator Temp (Colder)
Lights and functions should return to normal.
Hi
The sound from your refrigerator can be caused due to various reasons,please check this link bellow to troubleshoot your problem:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsnoisy
Please get back to us if you have further query else please accept the suggestion. Thank you for contacting fixya.com
