Question about HP Officejet 4215v All-in-One Printer
I HAVE A HP OFFICE 4315 ALL IN ONE PRINT.. I CANT GET FAX AUTOMATICALLY
I HAVE TRY EVERYTHING ON THE BOOK, AND IT DOESNT WORK, JUST IT HAVE WORKED MANUALLY.. I NEED TO GET THE FAX AUTOMATICALLY WHEN I AM NOT AT HOME.. I HAVE THE RING PHONES AS IS INDICATED, THE ANSWER MODE IN FAX.. I HAD HAD IN ANSWERING MACHINE BEFORE .. BUT IT DOESNT WORK!
COULD YOU HELP ME WITH THIS..?
Posted by marskog on
  • 2 more comments
  • marskog Oct 20, 2007
    I HAVE TRIED EVERYTHING ON THE BOOK, AND IT still DOESN'T WORK, JUST IT HAVE WORKED MANUALLY.. I NEED TO GET THE FAX AUTOMATICALLY WHEN I AM NOT AT HOME.. I HAVE THE RING PHONES AS IS INDICATED, THE ANSWER MODE IN FAX.. I HAD HAD IN ANSWERING MACHINE BEFORE .. BUT IT DOESNT WORK!
    I have set up it to fax, fax rings 2, answering machine rings 3. I have tried the other way too.. answering machine 3 and fax 5.. but didn't work automatically. I can only receive them if I press fax and then 2  to receive it.
    I have had other things attached, to the computer.. its all in one model and I can use it as a printer..the phone is in another room at this time but I also hooked the phone to the line 2 yesterday after many tries.
    I have a broadband.. DSL Wireless connection, and it has the special filter the phone company gave to us.
    We only have the one phone line to use between them for fax and phone.
    Thank you for your help!
    martha & leroy
  • marskog Oct 22, 2007
    Thanks for everything and trying.. i tried all you said and it didnt work I return the fax. Thanks for trying..
  • mooo Dec 10, 2007
    wont let me fax
Anonymous
Make sure it is not set to receive a unique ring! That was the problem with mine.
Posted on Jun 19, 2008
Soulvisitor
  • HP Master
  • 1,113 Answers
Set to fax, ring it from another phone, what happens? Count how many times it rings before answering (if it answers)
Do you have other things attached to it?
Where is the phone line attached to socket marked line or ext?
Do you use Broadband? Has the fax got filters attached before it?
Are there other phones in the house or has the fax a dedicated line?
DONT YELL
Posted on Oct 20, 2007
  • Soulvisitor
    Soulvisitor Oct 21, 2007
    A filter must be installed on phone line before it goes to fax, one also must be installed before phone in other room
    Forget answer machine function for now untill you can receive a fax in auto
    Do you have a duet phone system or destintive ring or some message bank setup? is distintive ring set to on or off?
    What hapeens exactly when you ring your number from another phone when machine is set to auto and fax with no answer machine function enabled.
    Does the fax pick up the line? ( it should if set right)  can you hear fax tone? or does it just keep ringing (not set to auto)
  • Soulvisitor
    Note If you do not use the supplied cord to connect from the telephone
    wall jack to the HP All-in-One, you might not be able to fax successfully.
    This special phone cord is different from the phone cords you might
    already have in your home or office.
     from your manual
My HP OfficeJet 4315 All-in-One printer defaults on FAX mode for some reason. How do I change it to print?
To better help you I did the work for you... I copied this from the HP forum which if you google your issues most of the time you find the answer!
Copied from: http://h30434.www3.hp.com/t5/Other-printing-questions/HP-officejet-4315-all-in-one-printer/td-p/411239
There are generally two print devices set up when an all-in-one with a fax is set up - one is the fax device and the other is the printer. Make sure you have the print device set as the default printer and/or that when you want to print that the printer and not the fax is selected.
Setting the proper printer as default would depend on your operating system, but for most versions of Windows you would go to the printers folder, right click on the non-fax version of the Officejet 4315 and select "Set as default".
Jun 17, 2011 | HP Officejet 4315 All-in-One Printer
My fax sound but dont received any fax
hi,
check whether the auto answer is turned on...
either u have the button on the front panel of the printer itself "auto answer" or u will have it in the fax menu...
press the menu button and scroll down to fax setup or advanced fax setup, make sure the auto answer option is turned on....
thanks and regards
agnel
Mar 19, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Fax failure message on hp4315
Please click on the web link given below and perform the steps as provided in the web page.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02151&cc=us&lc=en&dlc=en&product=1138342
This should fix the issue.
Have a great day!
Mar 14, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Hp officejet 4315 how to switch from fax mode to print
There is no "print mode", Fax, Copy and Scan are modes one can enter, printing on the other hand is done when a print job is detected from your computer
DRIVERS to suit download link
Download Manual and Setup guide HERE
Please rate solution as fixed.
Nov 19, 2007 | HP Officejet 4315 All-in-One Printer
FAX PROBLEMS.. HP Officejet 4315 All-in-One
after selecting FAX answer mode press the OK button to accept the changes.
Oct 20, 2007 | HP Officejet 4215v All-in-One Printer
HP Officejet 4215v All-in-One Printer Logo
140 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
