Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Safety key will not come out.
The  safety key will not go into the switch housing. I pushed it in and now it will not come out.
    Champion:
  • 313 Answers
If this is cmm1000 then there is a upgrade kit to change the unit to cmm1200 no need for the key
Posted on May 30, 2008
6ya staff
SOURCE:
Engine will not start by the key and the electric PTO will not stay on
Hi John, I don't know if your mower is push OR ride on so The links below are YouTube videos that might get you out of trouble... Also there's videos down the right side of the links that may help as well....... I hope these help......... CHEERS..
How to test a lawn mower Key switch....
How to test lawn mower key switch
How to test a solenoid....
How to test lawn mower solenoid
How small engine governors work....
How Small Engine Governors Work any governor setup
How to test lawn mower electrical safety switches....
Shows all safety switches disabled....
Disable all lawnmower safety switches
Apr 28, 2016 | Electric Garden
Lawnmower TRY3.5PMLA - trying to find manual for this online as it currently won' start.
Hi Anonymous, I don't know if your mower is push OR ride on so the links below are youtube videos that might get you out of trouble... Also there's videos down the right side that may help as well....... I hope these help.........CHEERS..
https://www.youtube.com/watch?v=Xi3p465MN1E
shows all safety switches disabled....
Apr 24, 2016 | Garden
How do I remove the ignition barrel from the cylinder housing?
This is a fairly straight forward job and with the correct tools shouldn't be very difficult. Your biggest challenge will be that your key is broken off since the key is instrumental in pulling the old switch out. Please read my instructions below fully before attempting the job.
Tools Needed - Flat & Phillip Head Screw Driver, Small 90 Degree Hook, A Straight Pick & T30 Safety Torx
Removal
1. You need to get the plastic column cover off from around the steering wheel by removing the two phillips head screws on the bottom side.
2. The guard will come apart in two pieces by pulling with medium to hard pressure.
3. You might need to tilt the column downward to get the guard off if its too high.
4. Now your cylinder will be exposed and you should see the safety torx bolt on the side of your cylinder. (Remove The Torx)
5. There will be a small lock button on the top opposite side from the torx bolt, You will need to get your key switch into the on position then use the 90 degree pick to push the small safety lock button at the same time while pull outward. (See #6 Before Moving On)
6. Here is where you could run into problems since your key is broken. I suggest taking a small flat head screw driver and turn your key cylinder with slight pressure towards the on position while lightly pulling outwards as if you where pulling the key out. You must also push that small lock button with your 90 degree pick as explained above all in one motion. (The cylinder will not release if the key cannot be put into the on position)
Note
I suggest purchasing your new key cylinder and examining it very well before stating the job. You will see the small safety lock button and can understand how everything works before you start.
Re-Install
1. There is a small spring inside where the key switch slides back into the ignition (It sits in a center hole) If that came out you will need to use the straight pick to slide it back into position.
2. Take your new cylinder with the key in the on position (Just like It was during removal) and get it into the position to slide back in.
3. There will be a small foot shaped lever at the bottom of the cylinder housing you will need to press downward at the same time your sliding the new cylinder back into place.
4. Take not also to insure the safety lock button on top of the new cylinder slides past the housing into place
5. You might have to turn the key cylinder slightly back and forth a few time while applying pressure inwards.
It sounds like a ton of work but it is really a straight forward job once you do it. I just wanted to explain every small detail you could run into. You will see most of the things I explained above on your own as your going through the motion.
I hope this helps you out and if it works please rate my answer as helpful. Good Luck!
Mar 26, 2015 | 2002 Honda Accord
How do I check your clutch safety switch in my 94 Saturn because I think is bad
have car out of all gears do not push down on clutch padle and turn the key if the car start = bad safety switch if the do not start = good switch
Jun 22, 2014 | 2000 Saturn SL
2007 BMW 750li key stuck in Ignition
Sounds like the neutral safety switch might be going bad.... The switch was originally designed as a safety feature to prevent starting the car in gear.... now it`s one component in a system with multiple interlocks (yet another byproduct of our litigation-prone society). The switch itself could be faulty, or possibly the linkage is out of adjustment, causing the gear selector to not fully engage the PARK position
Mar 05, 2013 | 2007 BMW 750 Li
97 honda accord manual clutch safety switch
try to have someone push the clutch and hold the key ...get something with a little weight on it and tap on starter
Aug 16, 2012 | 1997 Honda Accord
My Uncle gave me a Horizon T605 treadmill and the
horizon rct 7.6 , safety key off , replaced ,key.reed switch and board , still says safety key off ?? spoke to horizon several times and repair techs as well ,it can only be 1 of those 3 items , all switch & key tested good , must be a faulty new board ?? could it be anything else ??
May 28, 2010 | Exercise & Fitness
Dryer has power but wont run when i push start button
Problem is either the door switch or the safety thermal, fuse,. Open door and manually push door switch lever to see if you hear a click when depressed. If you do then the problem is the safety fuse located on the blower housing. Small white plastic piece with 2 wires going to it. Hope this helps. Rick
Mar 09, 2010 | Whirlpool Dryers
1998 TOYOTA COROLLA 5 SPEED. do not start
if it is totally dead then it could be in your park neutral safety switch, check underneath where the clutch is housed and push in with your hand and see if it engages
Aug 05, 2009 | 1989 Toyota Corolla 2 Door
Engine will not turn over or start when in park with key on.
You linkage is working properly it sounds like, especially if the indicator for "D, R, N", etc are lining up. However the linkage or the neutral safety switch may need to be adjusted. More than likely, it's your neutral safety switch.
The brake pedal release has nothing to do with the neutral safety switch when switching gears.
The brake pedal release is just a safety to prevent you from pushing the gear shifter accidentally. Actually, you should be able to start the truck without holding the brakes.
If the neutral safety switch is bad or misaligned, it'll do exactly what you're describing. If pulling it down in neutral starts the truck, then that's a sure indicator.
Feb 10, 2009 | 2003 Ford E250
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
219 people viewed this question
Top Black & Decker Garden Experts
gggg
Nick Olsen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
