Computers & Internet Logo
A
Anonymous Posted on Jan 06, 2014
Power button keeps blinking
Power button on printer always blink and cannot print.
5 Related Answers
Anonymous
  • 93 Answers
  • Posted on Dec 16, 2008
SOURCE: the power light keeps blinking and the printer wont print
Here is the solution on Hp web site for Blinking light
Click Here
Anonymous
  • Posted on Jun 10, 2009
SOURCE: printer light always blinking
either out of paper and something still waiting to print or inks low
hope this helps :)
Anonymous
  • 2567 Answers
  • Posted on Jul 21, 2009
SOURCE: my printer wont print and the lights keep blinking
Check page 10 in the manual at this link:
http://h10032.www1.hp.com/ctg/Manual/bpd09384.pdf
If the "Resume" & "Power" buttons & lights are the ones you refer to, then here is a page explaining how to resolve this issue:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=71895&prodTypeId=18972&prodSeriesId=71895&objectID=c00681585
Anonymous
  • 787 Answers
  • Posted on Oct 21, 2009
SOURCE: green light blinks continuously, printer will not
One or both print head are defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
Anonymous
  • 23 Answers
  • Posted on Nov 13, 2009
SOURCE: Printer is not printing but power light is blinking
You have a faulty ink cartridges. Try cleaning the contact points including on the carriage.
2answers
My canon ip 2700 printer blinks both the green and orange buttons whats the problem and how can i fix it
When both the green and orange buttons are blinking on a Canon iP2700 printer, it usually indicates an error or malfunction. The number of blinks can indicate the specific issue. Here are some steps you can try to troubleshoot the problem:
  1. Turn off the printer and unplug it from the power source.
  2. Check for any paper jams or obstructions inside the printer. Remove any jammed paper or debris.
  3. Check that the ink cartridges are properly installed and seated in their slots. Replace any cartridges that are low or empty.
  4. Restart the printer and see if the error message has cleared.
If the issue persists, you may need to reset the printer. Here's how:
  1. Press and hold the Resume/Cancel button (the orange button) for 5 seconds, then release it.
  2. Press and hold the Power button (the green button) while still holding the Resume/Cancel button.
  3. Release the Resume/Cancel button, but keep holding the Power button.
  4. Press the Resume/Cancel button twice, then release the Power button.
  5. Wait for the printer to reset itself. The green power light will blink and then stop blinking.
  6. Press the Resume/Cancel button four times, then press the Power button to confirm the reset.
  7. Wait for the printer to finish its reset process and print a test page.
If none of these steps resolve the issue, it may be necessary to contact Canon customer support for further assistance or to have the printer serviced.
1helpful
Keeps blinking. I've shut it off, and cancelled all print jobs - even unplugged it. Keeps blinking. Says there is an operator error
Try this:
1. Turn off printer (use button, don't unplug)
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
If this not help may the print head is defective.
1helpful
PIXMA MP 450
try these steps ...
1. Turn off printer
8. Your printer should respond as normal..
The power led of my printer in keeping on blinking.
This problem sounds like it has a print job waiting to print. make sure the paper is inserted properly and press the power button quickly and release. If something prints, it should stop blinking.
Cannon Pixma MP160. on/off light keep blinking and won't print
This some times works.
Also if you are using the Refillable ink cartilages stop they always cause major issues
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)Note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.(it must be turn off)
then turn it on again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
All The Best: Pineworks
Power light keeps blinking and will not print
Just keep pressed the power light button until the light goes off.
2helpful
2answers
Brother Printer HL 1240
OK figured out the sequence to resolve this error:
power off unit
unplug power cable for 1 minute
reset the power cable
open front door
press and hold the reset button under the lights
turn the power on
printer should then be reset
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Paper & Power button blinking after each print
Sure, there is a utility program called SSC utility for epson. IT allows you to override errors, freeze ink levels, and more. I'd say download it, and on the menu, go to extras and choose "soft reset". Only do this out of warranty though, as it will void your warranty. BUT it works GREAT!!!
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
