Question about Panasonic PT-51HX41 51" Rear Projection Television
Panasonic tv pt43lc14 steady flashing red light tv does not turn on
Anonymous
SOURCE:
Anonymous
SOURCE: Panasonic PT-50DL54J DLP TV Flashing Light
I had the same problems that most of you have been having, tv turning on and off, lights flashing in all different colors, having to unplug tv to reset and all of that good stuff. I noticed that most of the time this would happen once the tv would start to heat up, and I could hear the fan working a little harder. Well I am not an electrician but It was very simple to unscrew the lower bottom park of the tv, where the fan and most of the electronics sit, then I used an oxygen tank ( I work for a medical company ) to blow out all the dust in the tv, ( you can olso use the compressed air use for computer, but if grandma or grampa have some O2 laying around, it works really good, LOL. )and was very surpriced to see how dusty it was, then I removed the MAIN FAN ( you only need to remove three screws, however there's a box in fron of it, which you'll have to remove first in order to get to the fan ). this may sound a little complicated, but trust me it is not, once you have taken the fan off, clean it all the way around ( best to use a clean rag, the compressed air was not doing the job.
long story short, once I cleaned the fan and put it all back together. The TV still didn't work LOL, Just kidding, It has been working perfect for a little over a week.
If I can help in any other way, please e-mail me @ [email protected]
hope this helps.
Posted on Feb 19, 2009
abhishek33
ABHISHEK.C
  • 1239 Answers
SOURCE: red led light flashes 6 times and tv won't turn on
Hi friend,,,,,,
it is an indication of an error code ,,,,,,normally 6 blinking code refers to an power set up problem,see incoming voltage with an multimeter.......
thank u,,,,,,,,
Posted on May 03, 2009
Anonymous
SOURCE: panasonic pt-50lc13 shutting off
i'm on my 3rd bulb in 5 yrs. i hate this tv. this time my bulb light didn't come on. instead the power light flashed green fast then went to red flashing after. i took out the bulb and it's blown!
Posted on Nov 13, 2009
Anonymous
SOURCE: panasonic pt47wx52cf tv shut off and wont turn
i have the same problem red light flash 3 times and pause for5 secs and flash again 3 times
Posted on Apr 06, 2010
irefrige
SOURCE: PT61LCZ70K panasonic tv won't turn
have a tech clean inside cabinet and replace bulb , should be under warrantee if under 5 years old just had mine done free of charge from panasonic call 1 888 843 9788 they will direct you to a dealer. hope this helps
Posted on Oct 04, 2010
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
Panasonic tv PT50LC13 has no picture red light flashes when i turn it on green light flashes and turns off
This model was recalled by Panasonic-----massive recall. Start by having the lamp examined or tested---that is the place to begin.
Oct 17, 2012 | Panasonic Televison & Video
I have a pt43lc14 unit and the power light comes on but i do not have a picture. the temp light flashes 2 times every 5 seconds. can you please tell me what the problem is?
The "LAMP" LED light indication flashes or stay on too?Yes,than the tv projection lamp on the tv life are over.Tv require a replacement of new projection lamp.
Nov 23, 2010 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic pt43lc14 no red color. picture is good. cannot get anything to look normal color after trying to adjust color/tint/picture etc. Have alot of blues and yellow, and brown. seems like no red.
It appears that your light engine is broken, I have the same problem. Have you recently changed the bulb with a non-panasonic part bought on the internet. I did this and think thats what caused the problem. I believe the new bulb burn at a higher temp thus causing damage to the Light engine filters
Jan 04, 2010 | Panasonic PT-43LC14 43" Rear Projection...
Installing a Panasonic lamp for model number PT43LC14
You have two ways, you can call Technical Support, 1-800-211-7262, they should still be assisting with this, or the process is listed on pages 80-82 in the Operating Instructions, if you do not have the OI, here is a link to the PDF.
http://service.us.panasonic.com/OPERMANPDF/PT43LC14.PDF
Jun 15, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT43LC14 wont turn on
hi sir im tech in electronics ,if you go to change the lamp for another check the fan that is running cool sounds like the fan does not refresh the lamp and it burn again .
Jan 11, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
