Sylvania 6432GG 32" TV Logo
Question about Sylvania 6432GG 32" TV
How much does it weigh
Dimensions
How much does a kenmore coldspot 106 refrigerator weigh?
No data exists. Ball park figure by dimensions
https://www.google.com/search?q=kenmore+coldspot+106+weight
Weight of French door fridge.: Weight (lbs.) 331 Weight, Shipping 364
2helpful
Need to ship our Ride on Thomas Train and track. Does any one have the dimensions/weight of Ride on Thomas package including track please?
Use your bathroom scales. Weigh yourself holding the package and then weigh yourself without the package; the difference is your answer. Use a tape measure to measure the dimensions of the package.
If in the UK I would use Parcelforce for delivery.
Jan 12, 2021 • The Toys
I recently bought a 1992 5th wheel camper made by carri-lite. It's 32 feet long. What is the distance from the hitch to the trailer? What is the weight of this model!
all dimension and other information is available form the manufacturer web page or retail outlet
if not take a tape measure and measure it yourself and take the unit to a public weigh station and weigh it
Whats the difference between the ChocoVision Revolation 1 and 2?
ChocoVision Revolation 1:
-can hold 4oz-1.5 pounds
-Dimensions: 12.5"W x 10.5"D x 5.25"H
-weighs about 7 lbs.
-110v volts, 60 Hz
* Fully automatic micro-processor using forced hot air
* tempering takes about 30 minutes
VS.
ChocoVision Revolation 2
-same dimensions and can hold the same amount. same weight and electronics. also takes about 30 min to temper
contains some new features:
Digital Temperature Display
* Bowl Pause
* Manual Temperature Adjustment
* Overnight (standby) Mode
How much does this model weigh? I want to buy a tv stand weight limit states it holds a 100 lb tv tops?
A 46 inch Sony LCD FlatScreen tv weighs around 90 pounds.
If you look in your own tv's user manual it will tell you its weight in the DIMENSIONS section.
1helpful
What are the outsode dimensions of N3735W 37" TV
The physical dimensions of the TV itself: With Stand 37.0"x 28.6"x 11.6" (941mmx726mmx295mm)
Without Stand 37.0"x 25.8"x 5.5" (941mmx655mmx139mm)
When in the box with the stand the entire unit weighs 71.9 pounds.
I hope this helps.
I want to buy this Sansui DTV2760 but can't find the dimensions?
The DTV2760 is 26in wide, 23in high, 20in deep and weighs 81pounds. Try to find a DTV2798 at Walmart. It's almost the same tv with a better warranty.
DiMAGE E323 dimensions and weight
Dimensions: 99(W) x 62(H) x 34.5(D) mm / 3.9(W)x2.44(H)x1,36(D) inch. Weighs: Approximately 145g, excluding battery and storage media.
Top Sylvania Televison & Video Experts
Marvin
Marvin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
