Samsung washer error codes
NF error message
John Pottin
My washer will wash a load of clothes then the next load it will wash but when it comes to spinning out it sits and beeps a DP code.
Posted on May 11, 2014
4 Related Answers
Anonymous
SOURCE: Error code
My problem was simply that the screens where the hoses connect to the washer were clogged with rust from my well water. I cleaned them and we're back in business.
Posted on Sep 12, 2008
SOURCE: code nf shows on my washer
unplug for 15 mins and plug again to rest
Posted on Sep 14, 2009
Anonymous
  • 113 Answers
SOURCE: maytag neptune front loader washer has NF error code
Does it agitate and does the door lock light come on? Theres a panel on the back you can take off via 4 screws. Here you can check the belt and watch to see if it spins or moves at all. If the door lock light comes on, and you here the door click. Than chances are your motor control board is bad. Seen this many times. Im actually replacing one tomorrow on the exact washer.I believe the part # is 22004045. Heres a diagram. If the door doesnt lock than you need either a lock assy or a new computer for it. The computer is in the top panel where the timer is. If you look at it you should see a burnt resistor. If no burnt resistor than its more likely th lock assy. Ill try and find the part # for the lock and computer, and a digram. Hope this helps. Dave www.washermd.com
Posted on Dec 19, 2008
Anonymous
  • 232 Answers
SOURCE: I keep getting a nf error message. what is this
water fill valve screens may be plugged filling too slow or valve may be bad or is one of the hoses turned off
Posted on Dec 31, 2009
Nf code and donnot continue to next cycle
Samsung Washer Error Code NF (Fixed ...
www.appliancerepairlesson.com/.../samsung-washer-error-code-nf-fixed/
Jan 11, 2014 - What does the error code NF mean on a Samsung washer? ... You can set the washer to any cycle and test each solenoid for proper voltage. ... Next would be to check the screens on the back where the water hoses connect. ..... Hi, you don'thave any power to the water valve wires when it should be filling?
Dec 15, 2015 | Frigidaire Affinity ATF7000E Front Load...
What does nf code for a Samsung front load washer mean?
Water Inlet problem.
The 4E or NF error code indicates a water inlet problem or the machine cannot feed itself with water. Make sure the source water tap is turned on and check the water pressure.
To troubleshoot this error further, follow these steps:
Note: The steps below generally apply to all types of Washing Machine (Top Load, Front Load, Washer and Dryer Combo)
Step 1: Turn the machine OFF.
Step 2: Turn the water tap OFF.
Step 3: Remove the water hose from the tap and dispense the water into a sink.
Step 4: Remove the entire hose.
a. Check for Kinks.
b. Check for Clogs.
Step 5: Check if water supply is good.
Step 6: Check, remove, and then clean the first mesh filter (Brush under running water).
Step 7: Check and clean the second mesh filter.
Step 8: Test the unit by turning it on and by performing a normal wash cycle.
Step 9: If the issue persists, unit may require service. Inquire about the Warranty and Service Booking procedures for the unit.
Washing machine displays 4E or NF Error Code
Dec 02, 2015 | Samsung Washing Machines
What is Nf code
Dits a no fill error so you probably need to replace the water inlet valve. The link below goes into it in more detail. Samsung Washer Error Code NF Fixed
Oct 24, 2015 | Samsung SW62ASP Top Load Washer
FRONT LOAD WASHER samsung model WF338AAW/xaa
please see the cause and proceed to test the water inlet valve can be defective and replace it.use the common sense,see the diagram
God bless you
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
Sep 19, 2012 | Washing Machines
I have an error code that says nf
Hello & Welcome to FixYa
NF error in your washer is displayed due to no fill condition, when the washer tries to fill but is unable to nf is displayed. Please check the water inlet valve for any clogs and obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
Mar 06, 2011 | Samsung WF337AA Front Load Washer
I am getting an error NF during the washer cycle run. The cycle will not complete and has to be restarted. What does this error message mean?
Hello
NF error in your Maytag is displayed due to no fill condition, when the washer tries to fill but is unable to nf is displayed. Please check the water inlet valve for any clogs and obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
Nov 07, 2010 | Maytag Neptune MAH5500B Front Load Washer
Dec 31, 2009 | Samsung WF206ANS Front Load Washer
Washing Machines Logo
1,292 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
