Hi Dave.
The proper way to reset the DTC is using an OBDII scanner. Go to the nearest Autozone, ask to do a code scanning and to reset codes.
You can also reset the codes at home but you will need a scanner like this:
OBDII Scanner - U480. Here an example showing how to use a scanner tool to reset the codes.You can also try disconnecting the battery. That will reset the engine check light until the problem occurs again. It may not clear stored diagnostic codes. Make sure that you have the stereo anti theft code if needed.
Regards.
Ginko
