How to replace " cabin
The 2001 model Aztex has 2 cabin filters, they usually come 2 to a box when you buy them.
The charcoal carbon filters are the best.
Removal:
•Open the IP compartment door.
•Remove the rear inside IP compartment door.
•Open the HVAC module assembly access door
•Remove the RH passenger compartment air filter from the HVAC module.
•Slide the LH passenger compartment air filter to the HVAC module opening.
Remove the LH passenger compartment air filter from the HVAC module.
Installation Procedure:
•Install the LH passenger compartment air filter into the HVAC module opening.
Slide the LH passenger compartment air filter toward the left side of the HVAC module.
•Install the RH passenger compartment air filter into the HVAC module opening.
•Close the HVAC module assembly access door.
•Install the rear inside IP compartment door.
•Close the IP compartment door.
I Hope this information is helpful.
