Question about Metra Car Audio & Video
Ford ka2 manual
No heartier in car
I do i put oil in the heartier
Marlene,
It would help if you identified the make and model of the vehicle in question. Add it via comment to the original question. Car heaters don't have a separate water supply, the move heat from the engine to the cockpit by circulating hot coolant from the car cooling system. Most vehicles add coolant via the radiator or overflow reservoir.
Jan 09, 2015 | Cars & Trucks
Heartier fan switch works on only low
A/C fan works only on low. High Speed does not work.
Jul 22, 2012 | 1998 Isuzu Rodeo
I have a KA2 with a misfire, the plugs and coil pack have been changed but its still happening, what can i do now
Pull the plug for the injector. Use an ohm/volt meter to check the ohm's of the injector, should be about 12.5, but 11 to 15 is in range. Also check the plug, should have 12 volts on one wire with the key on. Let me know. Randy
May 20, 2011 | 1999 Ford Crown Victoria
Ford ka2 r reg caseete players code plaese
Remove the radio from the dashboard
Then post the SERIAL NUMBER found on a label on the readio casing
It normally begins with M * * * * * *
May 30, 2010 | Ford Car Audio & Video
I do not know to operate the rear windscreen wiper of my ford ka2 1998 model?can somebody please help?
not sure some had a switch on teh dash and others you push the wiper arm forewards
Aug 26, 2009 | 2000 Ford Focus
Our poper is burning out light bulbs in a about a 2 day period of time
Get either "Rough Service" Or "Appliance" bulbs. They are made heartier than regular bulbs. You can also use OUTSIDE type flood lamps. Make sure you have a cover over your bulb, incase it shatters.
Aug 07, 2009 | Cretors Antique Goldrush Popcorn Maker
Lens
If this is a manual focus lens, you will need to do two things (and an optional third thing.)
1) On the side of the camera, you have to switch the focus mode switch from "AF" (Autofocus) to "MF" (Manual focus) . . . Yeah. I know, you probably already did that. <grin>
2) When you press Menu, go to the Custom Setting and change the Allow aperture setting to on, so that the Pentax K100D will then work with manual control of the aperture ring. You need to do this or the K100D will not work with manual exposure lenses (M lenses) or even autoexposure lenses (KA, KA2, FA, etc.) when you move the aperture ring from the "A" position to one of the manual aperture settings!
3) This is optional, but in the Custom Setting you can also turn on the Fl in manual focus mode, so that even though you don't have autofocus capability, you will get a beep indicator when you have successfully managed to manually focus your lens.
I have a few nice manual focus lenses that I have a lot of fun playing with on my K100D.
Take care & Happing Imaging!
Glen
Jun 09, 2008 | Pentax K100D Digital Camera
Stk392
We have always used the 150 in place of the 110 and 120. My shop has never had a problem and they are a heartier IC.
Jan 13, 2008 | Toshiba 42H81 42" Rear Projection...
Car Audio & Video Logo
27 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
jdthefixer
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
