Water Heaters Logo
A
Anonymous Posted on May 16, 2017
Richmond water heater
I have a Richmond gas water heater that is only a year or so old. I have not water in the tank but can only get hot water to our kitchen sink and intermittently to the bathroom sink. None to the bath tub.. It started where we had rust build up in the valve of the tub that wasn't allowing e ought hot water to mix with the cold. Fixed that & it was working fine. Then all of a sudden no hot water at all to bathtub, or bathroom sink. Then it was intermittent for bathroom sink and kitchen. Now just kitchen. Any ideas?
Marvin
Level 3:
Top Expert:
  • Water Heaters Master 85,242 Answers
  • Posted on May 16, 2017
Marvin
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29024507
Points
266281
The water inlet to the heater must be plugged.
5 Related Answers
Anonymous
  • 11 Answers
  • Posted on Oct 27, 2008
SOURCE: On demand, tank less water heater
THE WATER IS RECIRCULATING IN THE UNIT. MAYBE CAUSED BY THE ACID. TRY INSTALLING A BACK FLOW PREVENTER
Dennis Sharp
  • 154 Answers
  • Posted on Aug 01, 2009
SOURCE: I GET NO HOT WATER
needs drop tube or full replacement
Anonymous
  • 61 Answers
  • Posted on Sep 19, 2009
SOURCE: No water pressure in bath tub after turning off hot water heater
It could be back flowing into the hot water heater tank which is not full because of the leak. Even though the valve is closed on the cold water entry side, there is probably no valve on the exit side. That is how it is returning to the tank.
Testimonial: "Thank you very much, Rick! "
Anonymous
  • Posted on Jul 25, 2010
SOURCE: i have a richmond gas hot water heater model
lock out code....turn off unit for 1 minute (unplug) press both arrows and hold for 5-10 sec... then enter L R L L ... R L R R...that should reset it.
A
Anonymous
  • Posted on Feb 27, 2011
SOURCE: New Richmond tankless water heater C8 error
I think error code C8 is #13
It has to do with air quality, lack of sufficient air, or lack of venting or dirty air filter.
Check following links to see if they have information:
Check following link for recall list:
http://www.tankless-recall.com/tanklessSearch.aspx
Manual shows error 05 or 13:
http://waterheatertimer.org/pdf/Rheem-RTG74IndoorOutdoor_owners.pdf
RichmondG40PVpower vent gas water heater
1) Type and brand water heater unknown.
Copy following link for Rheem-Richmond tankless error codes:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
2) Question posted under Richmond tank-type power vent.
Error code 24 appears to be Rheem-Richmond tankless water heater.
3) Add a comment with more information about type, brand, age of water heater including what you have tried so far.
4) Call service technician to catch up on required yearly maintenance.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
I have a recently installed richmond water heater. When the shower is running and someone turns the faucet on in the kitchen the water gets drastically colder in the shower. We didnt have that problem with...
Which type Richmond water heater?
Is this a tankless water heater or tank-type?
Tankless are notorious for 'cold water sandwich' under exact conditions you describe. You might need tankless with larger BTU burner.
Don't install a tankless.
If you have tank-type water heater, then I suspect a clog in the hot water line, or single-handle faucet cartridge in show is going bad.
Same problems can contribute to tankless problems.
http://waterheatertimer.org/Low-hot-water-pressure.html
2helpful
What does fvd interface malfunction mean
richmond lock out how to reset or restart my hot water heater
Popping noise from tank - 6G40-36FI
Sounds like water is over heating. (thermostat).Is water real hot.?
Need reset code for hot water talk
Go to www.richmondwaterheaters.com and see if they can assist you with it. Just click on residential products on the left side of the page.
Top Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Water Heater Expert? Answer questions, earn points and help others
