Question about Mitsubishi VS-50609 50" Rear Projection Television
Mitsibishi V5-50609 PROJECTION TV V- CHIP
NEED TO BY PASS THE V-CHIP CODE.
Posted by christine humphry on
1 Related Answer
Anonymous
SOURCE: i need help with my mitsubishi tv
Press QV+9 at the same time.
Posted on Apr 03, 2010
Why does my mitsibishi wd-607365 has white and black dots on it
After years of usage, the Mitsubishi WD-60735 starts to show some white dots, they begin to increase day by day all over the screen.
The problem is related to the DMD chip Part# 276P595010.
The part is about $200 you may find it used and cheaper on ebay.
Good luck
www.aaatvservice.com
Aug 09, 2014 | Mitsubishi WD-60735 Projection Television
V-chip block passcode
Hello
You must have its original remote control handset to unlock your Mitsubishi tv.
After you set the lock, you must use your pass code
to view a locked program, view the locked TV, view
a locked channel, cancel the lock, or enter the Lock
menus.
If you forget your pass code, you can view the locked
TV without entering your pass code. When you are
prompted for your pass code, press the number 9 and
QV keys on the TV remote control at the same time. This
process temporarily unlocks the TV.
When entering the Lock menu, this process deletes
your old pass code and prompts you to enter a new
pass code.
• You can either enter a new pass code to open the
Lock menu and make changes or press EXIT to close
the menu.
• If any of the locks are turned on and you exit the
menus when prompted for a new code, the old
code and all lock settings are retained.
• If all locks are turned off and you exit the menus
when prompted for a new code, then the previous
code is erased.
OK.
Mar 17, 2011 | Mitsubishi WD-62525 62" Rear Projection...
How do i get the v-chip lock code to unlock the parental lock from my Mitsubishi model code ws-55413
Bypassing the V-Chip Lock
After you set the lock, you need your passcode to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus.
If you forget your passcode, you can view the locked TV without entering your passcode. When your password is requested, press the number 9 and QV buttons on the remote TV control at the same time. This process temporarily unlocks the TV.
When entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode
hope this helps
John.
Jan 11, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Can not turn off the vchip channel lock on hd 1080
hello try this Bypassing the V-Chip Lock
passcode. This is done by pressing the
TV control at the same time, when your
password is requested. This process
prompts you to enter a new passcode. good luck
regards
shaun
May 14, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Tracking on my tv Mitsubishi 50707 50in
i have the same tv cant fix the tracking .model 50707 mitsibishi
Dec 26, 2008 | Mitsubishi VS-50707 50" Rear Projection...
V-chip
1. Select the "MENU" display by pressing the "MENU" button once.
2. Press the number buttons "5", "7", "7", "0" in sequence to select the "OPTION MENU" display.
3. Press the "ADJUST" button to select "INITIALIZE."
4. Press "ENTER
You can also push the 9 and QV buttons to temporary by pass v-chip.
Nov 04, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Mitsibishi vs60707
This a deflection problem. Both 2-3 and 2-4 are deflection. Most likely a verticale problem. a tech will need to fix it.
Mar 15, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Front panel locked and remote don't work
Are you sure there is not a problem with the TV set? The set will need to be on to unlock the front panel. Bypassing the V-Chip Lock on most Mitsubishi sets use a four-digit passcode that is required to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus. If you don't have the passcode, it is easy to bypass. This is neccessary if you forgot the code, purchased the set used, or if you simply don't feel like searching through your files to find it. To bypass the V-chip: You can view the locked shows by pressing the number 9 and QV buttons on the remote at the same time, whenever your passcode is requested. This process temporarily unlocks the TV. To reset the code: When you use the button combination 9 and QV while entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode. Good Luck
Mar 17, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi VS-50609 50" Rear Projection Television Logo
42 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
