SOURCE: Can't read a DVD-R that was produced by Canon DC210 DVD Camcorder
Canon DC210...To finalize the disk, you first probably want to have the AC adapter plugged in even if your camera does not require it in order to access the finalize menu option, as the process can be quite lengthy and use battery power -wouldn't want to run out in the middle of the operation....THEN....Make sure you are in VIEW mode -not record mode...THEN...Press the FUNC button on the side of the camera -you should then notice the FINALIZE option -among others -navigate to the actual finalize command using the joystick, then press it down and let it work its magic - try not to move it until it is finished. After it is finished -it can be removed and will be recognized by a dvd player, recorder or drive that is compatible with this type of disk in the first place, Apparently, this camcorder records video to the .VRO file type -so be sure any video editor/converter/player software on your computer recognizes this file type.
SOURCE: canot finalize dvd
I am having canon dc 210 digital camcorder, i cannot able to
view my dvd in my computer or in dvd player, why i dont know i tried my best, is any software is required to view in the computer .if say yes, please mail me the software immidiatly and oblige. with regards.my email is. [email protected]
SOURCE: CANON DC210 CAMCORDER DRIVER CD LOST
I HAVE LOST MY INSTALLATION DISK FOR MY CANON DVD CAMCORDER DC210...CAN U HELP ME IN FINDING AND INSTALLING THE SOFTWARE FOR THIS CAMCORDER SO THAT I CAN SEE MY RECORDINGS ON MY COMPUTER
SOURCE: Canon DC220 DVD Finalization problem
You have to plug the camera into the wall charger in order to finalize. I was having the same problem. Once finalized, I transferred the disk to the PC. You need DVD decrypter software in order to view the videos on the disk. Canon does not supply this. Canon recommended that I use one of several free downloads. They said download "DVD Decrypter" which I downloaded. Type DVD Decrypter into Google search and you will find it. It will rip it and download it to your computer. I then viewed the video with Windows Media. It works fine.
SOURCE: canon dvd camcorder DC210
Ok, Guest @ solution #1 and #3 solved this for me.
Step 1. remove battery pack.
Step 2. Plug in to outlet.
Step 3. Insert desired disc.
Step 4. Toggle down on the "mode" lever for "Play-back" mode.
Step 5. Press "function"
Step 6. Scroll to and select "menu"
Step 7. Scroll to and select "disc options"
Step 8. Scroll to and select "Finalize"
Step 9. Scroll to and select "Yes"
Follow prompts from there.
This worked for me.
Thank you all!!!
