Question about Nintendo DS Lite Console
Micro DS card
When i turn on my DS, with the micro in, it goes to the first menu, then when i touch the 'games' button the bottom screen turns grey and then it freezes, i have about 7 games on it, they all used to work before but now i cant access them, it never used to do this before, it works when i put it into the computer and other games work in the DS. the micro SD is only about a month old
  • dthenares Mar 15, 2008
    when i turn on the ds lite with the micro ds card inserted is displays the usual nintendo display then the screen becomes gray and displays a message "menu ?"
Anonymous
    Problem Solver:
  • 31 Answers
Get a new one or google or go to the company's website
Posted on Jan 21, 2008
When i turn my 3ds on you can see all the top screen but not the bottom screen
Plug it into the charger first.try calibrating the touch screen.
you can get to the calibration menu without touching the touch screen. First, turn off your system. Hold down L+R+X. While holding these buttons down, press the power button. This should take you to the touch screen calibration menu. (See Nintendo 3DS Operation Manual, Page 15)
If it doesn't work,you need to replace the bottom screen.
please note that all games dont require the bottom screen
Jul 01, 2012 | Video Game Consoles & Games
HOW DO I CALLIBRATE THE SCREEN ON MY DS thanks
Directly from Nintendo:
  1. Remove all games from the Nintendo DS.
  2. Turn the system on by pressing the POWER button.
  3. Press the A Button when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, use the Control Pad to to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button.
  5. Use the Control Pad to place the cursor over the orange icon that looks like crosshairs (the right-most icon), and press the A Button.
  6. Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves.
Mar 15, 2011 | Nintendo DS Console
My son has managed to change the language to german and we cannot change it back. It does not go into a screen to allow us to pick english. Any suggestions?
turn on your DS, touch the screen to open the menu(from top to bottom(DS Game, Pictochat, DS Download play, GBA Game) and underneath the GBA Game there is a little button that looks like an open DS... Touch that button, Now you will see a menu with a Wrench and Clock & Calendar, a Person, and a Cross.
Click on the Wrench, and then click on he icon that looks like a globe, form there just choose the language that you want.
Mar 01, 2011 | Nintendo DSi Blue Console
Its turning to german and how to fix it
If you mean the DS language is in German, then power on the DS without a game card inserted.
Touch the screen to continue.At the bottom-middle of the touch screen, touch the little DS icon, under the 'Es befindet sich kein Modul im Modulschacht' (There is no Game Pack inserted) message.
At the next screen, touch the Spanner (1st from left) icon. Touch the Globe icon (middle-left). Select 'English' presumably (top-left), or what ever language you want. touch 'A Bestätigen' (bottom right) or press the A button. At the next screen, touch 'B Go back' or press the B button, At the next screen touch 'B Quit' or Press the B button. Touch 'A Yes' or press the A button.
If you mean that a game is in German, then check within the settings of the game, generally you should look for a Globe type symbol, this should give you a menu to select a language from, or look for text such as 'Sprache auswählen'
I hope this is of some help, if not can you be a little bit more specific
May 08, 2010 | Nintendo DS Lite Console
Calibrate ds lite
If you would like to calibrate your screen...
Turn the DS on without a DS card inserted (or with auto mode turned off).
Then touch the DS icon in the bottom middle of the screen.
Press the far right yellow icon, with a crosshair in it.
You will then be taken to the calibrate screen.
Touch the small red squares on the screen as they appear.
Press confirm, exit menu.
Jan 06, 2010 | Nintendo DS Lite Console
When i turn on my new nintendo ds it says : Menu? and i cant do anything else.
may be the system firmware has crashed format the nintendo and u may get the problem solved
Sep 05, 2009 | Nintendo DS Lite Console
The language is in chinese
This is how you correct the problem.
1) Make sure there are no games in the DS
2) Turn on DS
3) At the splash screen touch the touch screen to access the main menu
4) At the main menu on the bottom there is an icon that looks like the DS opened. Click on this ICON
5) After Clicking on the icon you will appear at a menu that has four icons at the bottom. Click on the first one on the left. Should look like a wrench
6) Next touch the icon that looks like a globe from there if you can not read the word the top left cornner is the button for english.
7) Touch that button in the upper left cornner and touch the bottom (very bottom that has A or B) click. This should automatically change the words to english. This should fix the problem
Feb 25, 2009 | Nintendo DS Lite Console
Settings are in Spanish when I want it in English
  1. Remove all games from the DS.
  2. Turn the DS on by pressing the POWER button.
  3. Tap screen using the stylus when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, use the stylus and tap on the Settings Menu Panel at the bottom middle part of the screen.
  5. Tap the wrench icon (the leftmost icon).
  6. Tap the globe icon.
  7. Tap the box for the language you wish to choose.
  8. Tap the bottom-right box to confirm the selection (it says "Confirm" if the menu is in English).
  9. Wait for the the confirmation message to disappear, then tap "Go Back," then "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Jan 10, 2008 | Nintendo DS Console
Nintendo ds
Setting the Time and Date
Changing the time
  3. Tap the screen using the stylus when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, tap the stylus on the Settings Menu Panel at the bottom middle part of the screen. icon_settings.gif
  5. Tap the calendar/time icon (the blue icon, second from the left). icon_clockdate.gif
  7. Tap the up or down arrows above the hour and minute to change the time. When finished, tap the "Confirm" button in the lower right corner.
  8. Wait for the the confirmation message to disappear, then tap "Go Back," then "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Changing the date
  7. Tap the up or down arrows above the month, day, and year to change the values. When finished, tap the "Confirm" button in the lower right corner.
Dec 30, 2007 | Nintendo DS Console
Thing goes to game instead of the menu bar when DS game is in.
you can set the ds to auto load the game from the options menu, so turn off the system take out the game cards (both DS and advance games) and then turn on your system, that should cause your system to start displaying the pictochat/ ds download play screen at the bottom of this you will see a ds pic tap that and you can get into your settings and change them from auto to manual.
Hope that helps ;)
Dec 07, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
Top Nintendo Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Anon
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
