Question about Kenmore 15129 Built-in Dishwasher
MAYTAG DISHWASHER STUCK WITH LIGHT BLINKING
THIS HAS HAPPENED BEFORE..JUST NEED THE CODE TO UNLOCK IT. IT REQUIRES A SERIES OF BUTTON PUSHING TO MAKE IT MOVE ON.
Posted by CASEE on
  • Anonymous Dec 21, 2007
    CODE L
Anonymous
    New Friend:
Try holding down "Heated Dry" for about five seconds, until the light switches off. You should be good to go.
Posted on Nov 23, 2009
  • tracy Jul 24, 2013
    wow...this worked perfectly! thank you! i was about to go buy a new one!
Anonymous
We have a Kenmore model 665.1602 and my wife begged the repair guy to give her the code to unlock everything on the system. The code is......Drum roll please....... <high temp wash> <heated dry> <high temp wash> <heated dry>
Posted on Feb 08, 2008
  • vickie cherry Aug 06, 2011
    FINALLY, I have been trying ALL morning to find someone, anyone to tell me that code!!!! THank you thank you thank you!
joe breeze
My kenmore dishwasher model 665 1700 has the normal wash and the heavy duty wash lights blinking on both the key pad
Posted on Apr 04, 2011
PLEASE READ NEED HELP ASAP
What requires an unlock code?
Jun 05, 2013 | ASUS Computers & Internet
I have lost my unlock code for kicker sx650.1
I have never in my entire life seen an amplifier that requires an unlock code. What seems to be the problem with the amplifier?
Dec 17, 2011 | Kicker SX650.1 650W Mono-Block Amplifier...
How do i unlock my lg 8600 flip
  • Flip open the phone so the keypad is exposed and press any button to wake the phone up from sleep mode.
  • 2 Enter the four digit unlock code using the phone's keypad. The default code is the last four digits of your cell phone number.
  • 3 Press the "OK" button to submit the code and unlock the phone.
Forgotten Code
  • 1 Turn the phone over and remove the battery cover and battery. Press down on the upper plastic edge of the cover and slide it in a downwards motion. The plastic cover will give way to the battery which can be pulled out of the phone.
  • 2 Locate the sticker on the phone hidden behind the battery. Write down the last four digits of the ESN DEC number.
  • 3 Replace the battery and battery cover and turn the phone on by pressing and holding down the "Power" button.
  • 4 Flip open the phone so the keypad is exposed.
  • 5 Enter the last four digits of the ESN DEC number. Press the "OK" button to submit the code and unlock the phone.
Power the phone on and select the "OK" button. This will trigger the phone to ask for the password.
  • 2 Press "OK." Sometimes this is simply all it requires. If not, move on.
  • 3 Enter the last four digits of the phone's number. If this doesn't work, continue to the next step.
  • 4 Enter "#4357" or "*4357." "4357" stands for "LOCK" on a traditional telephone's alphabetic keypad translation. This is the default unlock code for certain LG telephones.
  • Dec 06, 2011 | LG Cell Phones
    To unlock the bolt no code is needed... just by pushing the lock button it unlocks what do i have to do to make it function proporly
    You need to reset the lock, so it will be set to the correct handing (left or right hand door).
    Open the door and extend the lock bolt. Remove the battery. Press the reset button three times and wait 20 seconds. Push and hold the lock button, while inserting the batteries. Hold the lock button until the bolt starts to move. Allow the lock to complete it's learning cycle.
    Program a new code and test.
    Jan 09, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
    I need a raidio code for a 2001 mitsubishi galant- Model # MR472958 Serial # 99E55715 Ref # CQ-JB1911LA
    Your code is 3053
    Use preset 1 to set digit 1, preset 2 to set digit 2, etc
    Once the code displayed is correct, push your unlock button to unlock the radio.
    The unlock button varies by model, but is always either AM/FM, CD, or TAPE.
    There is no penalty for pushing the wrong unlock button as long as your code is correct.
    If you have locked out the radio from failed code attempts (radio reads "OFF", you will need to leave the key in the ACCESSORY position with the radio displaying OFF for approximately 1 hour. After which time the radio will revert to CODE and you can enter your code then.
    Oct 30, 2009 | 2000 Mitsubishi Galant
    Control panel lights blinking
    I have the same dishwasher with the same problem, try pushing the delay/resume button, then the drain/off button. When the lights go off start your wash cycle.
    Sep 17, 2009 | Maytag 24 in. MDB5600A Jetclean II...
    My 2610 requires an enter restriction code when I try to unlock it. Please help me. And I also need the unlock code. The imi number:011750006488958
    My 2610 requires an enter restriction code when I try to unlock it. Please help me. And I also need the unlock code. The imei number:354808016617092
    Aug 22, 2009 | Nokia 2610 Cellular Phone
    2006 BMW 323i Passnger Door lock will not lock / unlock w/ remote
    Replace fuse 57 (15 amp) then disconnect battery and wait 30 to 45 minutes before reconnecting the battery.
    My 2006 BMW 325I had the same problem with the door locks not responding. I checked all related fuses and found #57 (15 amp) was the only related fuse blown. I put in a new fuse and it still would not work. I then disconnected the battery for a while then once I reconnected the battery everything worked fine.
    I believe I blew the fuse while repeatedly pushing the unlock button rapidly while walking across the parking lock to the car. I suggest only pushing the unlock button only once or twice.
    Jul 28, 2009 | 2000 BMW 3 Series
    I need instructions to nokia 2680 slide.. please help me.please:(
    I'm not sure if this works with all Nokia Phones but it's worth a try. Try pushing the "unlock" button then pushing the " *+" button within 3 seconds of pushing the unlock button. That worked with one of the older model Nokia's that I owned before.
    Jul 20, 2009 | LG VOYAGER VX10000 Cellular Phone
    Blinking lights, unresponsive
    I went to the Maytag site looking for a manual. None existed for my model, but I looked up won't start under the FAQs. The advice said to push the cancel button twice. My model doesn't have one, so I just started at the left side of the control panel and pushed each button twice. pushing the dry button twice made the lights stop blinking. i pushed the wash button and the unit started.
    May 08, 2009 | Dishwashers
    Kenmore 15129 Built-in Dishwasher Logo
    3,689 people viewed this question
    Top Kenmore Dishwashers Experts
    Ron Rak
    Ron Rak
    Marvin
    Marvin
    Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
