Question about Philips 42PF9966 42 in. HD-Ready Plasma Television
I have a problem PHILIPS 42PF9966/12 PLASMA, turns off after 30 minutes and restarts after 5 minutes and so on .. I appears red LED that flashes 8 times. I went into service mode and shows me 003 errors anybody knows what to do, or what part needs to be changed?
If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. Error codes details are given. Try this link too. http://electro-medical.blogspot.com/
Posted on Jan 06, 2014
SOURCE: philips tv error code
1 long and 4 short blinks for this model is specific to class d audio amplifier on small signal board. if it is intermittent where this sometimes happens and you can unplug and replug and power back on would be related to the firmware version but if version is correct you would still need to replace ssb
Posted on Aug 17, 2008
SOURCE: Philips 42PF7220A/37 Chassis Number BP2.3U
I think its something on the picture frame board or on the line output board. I would sway to the line output simply because I think but not sure that error code is linked to the line output stage plus when you unplugged the cable the voltage seems within parameters. Good luck.
Posted on Oct 03, 2008
SOURCE: 42" philips plasma
when a television turns off by itself and flashes as you say, it indicates that there is a problem inside the tv. If you keep trying to turn it on you may do more damage. It could be something as simple as a faulty fuse inside. If you have no expierience with electrics I suggest you get it checked out by a professional. I had a similar problem with another tele model and it was the fuse in the back of the tele that needed changing. I did try to this on my own but unfortunatley didn't have the right fuse so i took it to a repair shop and he done it really quickly.
Posted on Oct 23, 2008
SOURCE: Red LED blinking after turn on the TV (Philips Plasma 42PF9631D
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also
ensure that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem with no receiver box
or dvd connected.
If that does not work, and you keep having a flashing
led on front of the TV, and tv turning off by itself after a while,
that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The
internal circuits are jammed because of electrostatic
charges accumulating on capacitors, or because of a wrong voltage read
by the main chip on your monitor controller board. this started the
protection circuit.
2 The protection circuit detected a wrong
voltage or abroken contact, identified an internal fault and kicked in
, startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults
that can occur are a blown capacitor on power board, a
convergence IC has blown, or a fault on Digital board.
Check also
the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you
can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 21, 2009
SOURCE: Philips 42'' Plasma TV 42PF7320A/37 red led error codes
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
Aug 23, 2015 | Roku HD Player (N1100)
Jul 02, 2008 | Dell 5110cn Laser Printer
Jul 04, 2011 | Philips 42PF7320A 42 in. Plasma HDTV
Jun 01, 2010 | Philips 42PF9631D 42 in. Plasma Television
May 14, 2010 | IBM Wheelwriter 30 Typewriter
Oct 23, 2009 | Canon imageRUNNER C3200 Copier
Feb 23, 2009 | Philips 64P8341 64" Rear Projection...
Aug 04, 2008 | Philips 42PF7220A 42 in. Plasma Television
Aug 03, 2008 | Philips 42PF7220A 42 in. Plasma Television
Jun 14, 2008 | Philips 42PF9630A 42 in. Plasma Television
Jan 15, 2012 | Philips 42PF9966 42 in. HD-Ready Plasma...
Oct 25, 2011 | Philips 42PF9966 42 in. HD-Ready Plasma...
144 people viewed this question
