Goldstar MV-1501 Microwave Oven Logo
M
Mike murphy Posted on Jan 05, 2014
The front plastic on the door came loose. How do I fix it?
The door latch broke
Slightly different model, but this will help you fix it.
https://m.youtube.com/watch?v=JqeeGBhRwFw
Door release buton does not open the door
You can disassemble the microwave oven and check out the release mechanism. You'll find several hooks that hold the door closed and a linkage mechanism to the door opening button. There may be a broken piece of plastic or maybe just a loose or missing screw that holds linkage together. In the case of a broken plastic part, you can fix it with a 2-part epoxy adhesive, but you'll need to permanently splint across the break with a piece of metal or strong plastic that you've scavenged from somewhere. Before epoxying the splint in place, rough up all plastic surfaces where you want the epoxy to stick well.
Good luck.
Microwave oven ddoor will not latch
Usually the spring inside the door has broken or come of the plastic tabs it is connected to. To fix requires you to take the door apart - not a job for amatures.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
PMOR30S door hinges are loose
The service manual for the PMOR30 is here.
The part list is here.
You can order Dacor parts by part number here.
3helpful
NEFF H5430NOGB Integrated oven - door won't close, the ;hooks on the door itself seem to have gone loose so they ill not clikc inot place when trying ot close, door just flops open.Amy ideas???
I had this problem. The spring inside the door which pushes the the latches down had broken (plastic peg had broken off).
I managed to fix it by attaching the broken end of the spring to the door frame using a small nylon cable tie using the small hole in the plastic fingers which was already there. Note you need to remove the inside door surround.
See the following link to remove the plastic cover on the door
http://www.fixya.com/support/t1267577-replace_front_glass_door_neff_microwave
I had an interim solution which was to tie some thin string to the latch and feed it under the door and pull on the string when closing the door (when it should be latching.
It was
All the lights and buttons on the front of my Frigidaire PLMBZ209GC work but the turn table does not turn and the fan does not run and it does not heat. It counts down and the cook light beside the timer...
Hello :
That problem could happen because of a bad door switch .
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
That could happen because of slamming the door and not closing it gently .
WARNING : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
1helpful
Won't heat
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
or it could be problem with the control panel .
good luck .
please rate !
Sear's microwave falling apart
If this is and Over the Range micro, the exhaust fan needs to run ANYTIME the cooktop is on. They make things for quantity and not quality, so the plastic has little tolerance for heat. Running the fan, diminishes heat off the front of the unit. Also, the micro MUST be at leat 24" off the cooktop.
9helpful
2answers
Microwave handle replacement
How to replace handle on GE Advantium SCA1001DSS.
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
14helpful
4answers
Loose microwave door
My over the range microwave had a loose door, it sagged when it was open but you could lift it to close. Called repair person he said no it could not be fixed. You could see the bottom hinge was loose and slipping. I loosened 3 screws that holds the bottom on the microwave -you have to do this to change the light bulb also. The bottom hinge on the door was loose there was a hole there, so took a screw and nut to hold the hinge in place..I am a 70+year old woman-if I can you can.
Top Goldstar Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
