projection tvs can display white dots from the dust that is on the reflector mirror your lamp shines the picture on before it is reflected onto the front screen of your tv, one must be very careful when cleaning this, may be worth a service man doing it for you
Your dlp chip is going bad and cannot be fixed economically. Several of the mirrors on the chip are hanging up and they won't come back. It will just get worse. My Sharp XR32X is doing the same thing. New projector time.
I have several white dots all over the screen. They're more that pops up as I watch it and the dots never goes away. Does anybody know what I need to do to fix this problem? Thanks..
White dots are caused by the DLP chip failing.This part must be replaced to get rid of the white dots. Samsung is covering the cost to repair this problem on several models. Ypu can call 1-800-samsung to find if your unit is covered.
white dot is from a failure in the dlp chip. it controls 1000s of tiny mirrors which help make up your pix, when the mirrors get stuck a white dot appears. over time more will pop up. Probably in the $300-$500 range to have someone repair.
call samsung. there are aware of this issue with several of their dlp sets. To avoid a class action lawsuit, they've extended the warranty of several models to cover the very issue. give samsung a call and see if you model is covered. i just got my 46" repaired at no cost and without a warranty.
sound like you have a bad dlp chip. this happens to a lot of samsung dlp tvs. some of the mirrors are stuck. they can appear as black dots or white dots and it usually gets worse over time.
