Computers & Internet Logo
A
Anonymous Posted on Jan 05, 2014
Leappad problems when i switch leappad ultra on it show me a picture to connect to comupter and when I do nothing happens
pauline scott
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 19, 2014
pauline scott
Contributor
Level 1:
Answers
Questions
0
Helped
181
Points
0
Leappad wont work off charger
Forgot code for the leap frog and it wont let me get wifi
Wi-Fi Troubleshooting - LeapFrog
www.leapfrog.com > ... > LeapPad Ultra & Ultra XDi
LeapFrog EnterprisesPlease note: If you have gone through all the available troubleshooting on this page and still cannot connect to Wi-Fi, you can purchase and sync apps to your ...
LeapFrog Customer Support ' Help & Support For LeapFrog ...
www.leapfrog.com/en-us/support
LeapFrog EnterprisesKid-Proof LeapPad Warranty ... LeapPad Ultra Getting Started Video ... I forgot the Parent Lock code for LeapTV, how can I access Parent Settings? What is the ...
LeapPad Wi-Fi Support: Setup - LeapFrog
www.leapfrog.com > ... > Wi-Fi Troubleshooting
LeapFrog EnterprisesIf you need to set up your LeapPad's Wi-Fi connection, please click on of the links ... Click here to view the step-by-step instructions on changing the current Wi-Fi ...
LeapPad Ultra - Parent Settings - LeapFrog
Feb 03, 2016 • Toys
How do i obtain a parent code for my child leap pad ultra my child started the ultra before i could set up.
Forgot Parent Lock code on LeapPad Published 07/10/2013 01:47 PM ' Updated 06/15/2015 04:11 PM
I forgot my Parent Lock code, how can I access parent settings on the LeapPad3, LeapPad Ultra, or LeapPad Platinum?If you forgot the four digit parent lock code you set up for the LeapPad3, LeapPad Ultra or LeapPad Platinum, you may retrieve the code with these steps:
1. Using a computer or other device connected to the internet, go to www.leapfrog.com
2. Click "Log In/Register" (or "My Account" if already signed in) on the top right of the page.
3. Sign in with the email address used to set up the LeapPad.
4. You'll land on the "My Account" page.
5. Click "Account Information". Directly beneath the orange "Edit" button you will see the Parent Lock code information for any LeapPad3 or LeapPad Ultra set up using this account.
How do i reset the 4 digit parent code on my daughter leap frog ultra
How can I reset my child's leapfrog ultra password
How do I recover from a forgotten password on my Leapfrog Ultra?
2answers
For 4 digit pass code on my leappad ultra
Resetting your leappad ultra isa breeze. First thing you need to do is to download and install Leapfrog connect. If it doesn`t download, there`s an offline download option available. After installing it, connect your leappad ultra with the usb cable to the pc. power it on. it should get connected. If it doesn`t maybe your anti virus software is blocking it. If this happens, go to your antivirus software settings and under firewall rules, select allow for leapfrog connect .exe. Then it should detect your leappad ultra. Go to left hand top corner , select My Products. Then select your leappad ultra. Then goto Settings on the right top corner and in the pop up, select Reset. It will take around 15 - 20 mins to reset it. All data will be erased. Hope it helps
http://youtu.be/dnyle_-2aDYw
How to reset
Download and install Leapfrog connect. After installing it, connect your leappad ultra with the usb cable to the pc. power it on. it should get connected. If it doesn't maybe your anti virus software is blocking it. If this happens, go to your antivirus software settings and under firewall rules, select allow for leapfrog connect .exe. Then it should detect your leappad ultra. Go to left hand top corner , select My Products. Then select your leappad ultra. Then goto Settings on the right top corner and in the pop up, select Reset. It will take around 15 - 20 mins to reset it. All data will be erased.
Forgot password to leappad ultra tablet unable to access parent user account
Answers others found helpful
Leappad ultra problems
take it to the store where you got it or to the group at the best buy called geeks they can normally handle these things and it may just need to be reset and charged
13helpful
3answers
Factory reset of leappad ultra
Download and install Leapfrog connect. If it doesn't download, there's an offline download option available. After installing it, connect your leappad ultra with the usb cable to the pc. power it on. it should get connected. If it doesn't maybe your anti virus software is blocking it. If this happens, go to your antivirus software settings and under firewall rules, select allow for leapfrog connect .exe. Then it should detect your leappad ultra. Go to left hand top corner , select My Products. Then select your leappad ultra. Then goto Settings on the right top corner and in the pop up, select Reset. It will take around 15 - 20 mins to reset it. All data will be erased.
Sep 12, 2013 • Toys
Grand Canyon Tech
Grand Canyon Tech
