Won turn on after power surge no red light in front is the power supply in the main board
SOURCE: no power,red power lights keeps flashing.
Just my coment THis tv has a complex system that include a digital signal porcessing in a high levle technology to show a good performance, i myself work on the development of that model, we was thinking we are best, for improve that many eng. dedicates almost all life to have that technology in our rooms, I offer my apologize for that but many eng dedicates all year 18 hours a day to fix that, thanks
SOURCE: Panasonic TH-50PE700U red light flashing 6 times
Replaced the sc board and tv works fine again.
SOURCE: plasma 50 inches dont turn on
The power supply board is dead.Tries the websites like Shopjimmy.com,Ebay.com to buy the refurbish power supply board for the replacement.
SOURCE: Panasonic viera Plasma TV model TH-P42X10A The tv
The power supply board of the television is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
SOURCE: Panasonic TH-50PX80U won't work after
Hello
If cable box converter has damaged, there is no question about the main board of your TV. It has been damaged. Before replacing it, you have to check the power supply board also. If the TV has been pluged to power supply, surely there will be fault to it also. We can't predict the exact fault occurs during a lightning, because Trillions of volts are passes nearby. You have connected the TV with cable connection and to the home power supply too.
Just replace the main board first. If it does not hel you, replace the power board too. I hereby send picture of both boards.
The first one is main board and the other is power supply regulator board.
