Computers & Internet Logo
A
Anonymous Posted on Jan 05, 2014
Zebion pci parallel card driver
The driver disk dont match with windiws 7 starter
5 Related Answers
A
Anonymous
  • Posted on Feb 22, 2008
SOURCE: PCI PARALLEL CARD WINDOWS VISTA X64
There are know compatibility and driver problems with Vista. Please visit the Microsoft update website for updates and driver issues.
Anonymous
  • 22 Answers
  • Posted on Jul 31, 2008
SOURCE: sound card
You can try download your driver as below link :
http://support.creative.com/downloads/download.aspx?nDownloadId=1843
Anonymous
  • 23 Answers
  • Posted on Nov 06, 2009
SOURCE: install a parallel pci card on Windows 7
If Windows 7 doesn't automatically detect it and install the drivers, browse the company's website for Vista drivers. If that fails, search Google with your model and drivers on the end. Aside from those solutions you may have to get a new card. Hope it helps!
nonontech
Lebanon Raingam
  • 4737 Answers
  • Posted on Apr 21, 2010
SOURCE: Audio and video device won't start I get a code 10
How to Fix a Code 10 Error
A Code 10 error usually occurs due to:
  • Missing device driver
  • Malfunctioning device driver
  • Incomplete device driver files
If the device due to which the error has occurred contains the valueFailReasonString in its hardware key, then this string is displayed as an error message. Otherwise, the device displays the following error message:
This device is either not present, not working properly, or does not have all the drivers installed. (Code 10)
Most of the time, you can resolve this error by updating the device driver for the faulty device. To update the driver, select the Systemoption from the Control Panel. In the System Properties dialog box, select the Hardware tab, and then select the Device Managerbutton. Scroll through the Device Manager window and identify the faulty hardware device. Right-click on this device and then select theUpdate Driver command. Next, follow the screen instructions to update the driver of the selected device.
Causes of System Errors
System Errors Usually Occur due to:
  • Device driver conflicts
  • Corrupt or damaged software files
  • Malfunctioning hardware
  • Corrupt or damaged system registry
  • Virus or spyware infection
Steps to Prevent System Errors
With a little vigilance and extra precaution you can easily prevent most system errors. Some of the tasks that you can perform to prevent system errors are listed below:
  • Keep your operating system, device drivers, and software applications updated with the latest hot fixes, security releases, and updates.
  • Run regular antivirus and anti spyware scans to keep your PC free from harmful and disastrous malware. Always keep these software updated with the latest security releases so that your system is always protected against malware infections.
  • Avoid opening attachments of unsolicited emails and visiting dubious websites.
  • Do not download freeware and shareware from websites whose authenticity you aren’t sure of.
  • Be very careful while downloading ActiveX controls from various websites. ActiveX controls provide their master with complete control over your system and therefore, a malicious ActiveX control can cause severe damage to your system and may also enable a hacker to steal your personal information.
  • Last but not least, perform regular registry maintenance to ensure that your registry is free from errors. 90% of all system errors are connected to the system registry in one way or another. You can easily perform registry maintenance with the help of a registry cleaner such as Ccleaner/Regine. These softwares will provide you with a simple-to-use graphical interface and enable you to scan and clean registry errors in just a few mouse clicks.
It is a very good idea if you run a registry cleaner using Ccleaner/Tuneup/Regine etc...
Anonymous
  • 567 Answers
  • Posted on Jun 13, 2010
SOURCE: need vista or 7 drivers for an Atheros 802.11g
Hi there thanks for asking, please go to http://download.cnet.com/1770-20_4-0.html?query=wireless+adopter+drivers&tag=srch&searchtype=downloads&filterName
you can get free downloads of the drivers.
If this solution help please vote and rate it. thank you
Epson gt 12000 scsi
We don't have enough information. The SCSI card has to match the bus of the computer ie: ISA, PCI, ect. Adaptec.com is a good place to start. Then you have the problem of a cable with ends that match the card and the scanner. The Epson GT has a parallel interface which might be a simpler solution.
heres the web site download from here http://www.zebion.in/computer-peripherals/
Adding discrete graphics card to p6stp-fl
!O_O!
1) Unplug the computer from power.
2) Press the Power On button in, and hold it in for a count of 10 seconds. Let go. (HAS to be 10. Count)
Do this same procedure TWO more times.
(IF the Power On LED flashes for a second, keep repeating until it doesn't)
What you are doing is clearing CMOS Error Codes, and resetting BIOS Setup parameters back to the factory default settings.
3) FOLLOWING Anti-Static Precautions remove the graphics card.
Plug the monitor back into the Integrated (OnBoard) graphics, of the motherboard. (VGA connector)
4) Plug the computer back into power. WAIT 1 minute, turn the computer on.
5) When Windows has loaded wait a couple of minutes, then take that graphics card's Installation (CD) Disk, and put it in the optical drive.
If the disk doesn't start loading after 10 seconds, go to My Computer, and double-click on the drive letter, next to the optical drive, the Installation Disk is in.
When asked choose all software. Nvidia Control Panel, and drivers.
Your computer will keep on using the Integrated (OnBoard) drivers, for graphics. It will Not use the drivers, and software you are installing now, until the graphics card is physically installed.
Install all software. If you are asked to restart your computer -> NO
Close all windows, go back to your desktop screen.
Turn the computer off normally.
(Start > Turn Off Computer > Turn Off)
6) Unplug from power, follow Anti-Static Precautions.
Unplug the monitor from the motherboard. Physically install the graphics card.
Plug the monitor into the graphics card. Close the computer case.
7) Plug into power. WAIT 1 minute, turn the computer on.
You may have to go into Nvidia Control Panel, and set the correct parameters for your monitor. (Screen Resolution / Color quality )
Clear CMOS Error Codes, and reset BIOS Setup back to factory settings doesn't work?
You get to go back into BIOS Setup, and set the submenu you changed, (Or submenu's), back to the factory standard setting.
(F6?)
You are trying to use the OnBoard graphics drivers for the -> graphics card. This = NO.
You need THE drivers for the graphics card installed F-I-R-S-T.
(OnBoard. ON the motherBOARD.
Used to be used for Integrated Graphics.
Makes it easier to understand if you use OnBoard Graphics )
Why?
When a device, (In this case a graphics adapter card), is installed, Windows 'breaks it's neck' to find suitable, matching drivers.
If THE drivers are not there, Windows will match up one of it's THOUSANDS of generic drivers.
This = No.
You need THE drivers already installed. Windows looks to see what device is installed, then finds THE drivers needed.
Regards,
joecoolvette
1helpful
I have Wolfdale 1333-D667 motherboard which Supports Dual Channel DDR2 667/533 memory. Can i upgrade it with a DDR3 Graphics card?
atlantisshak, you can use a graphics card with ANY graphics ram memory.
A graphics card has it's own Processor, and graphics memory.
Doesn't depend on the system resources, ( Processor and Ram Memory)
GPU = Graphics Processing Unit, the graphics card's processor,
http://en.wikipedia.org/wiki/GPU
Doesn't matter if you use a graphics card, that has GDDR3, or GDDR4, or GDDR5, graphics ram memory.
I do however, recommend using a PCI Express graphics card based on the 2.0 technology. (PCI Express 2.0), and NOT the PCI Express 2.1 technology.
Could have problems.
For additional questions please post in a Comment.
Regards,
joecoolvette
{ ALSO;
Make SURE you,
1) Windows running on the computer, install the graphics card's Installation Disk. (CD disk)
AFTER loading the graphics card's 'Control Panel', and drivers,
DO NOT RESTART.
Close all windows, go back to the desktop screen. Shut the computer down normally.
THEN unplug from power, AND follow Anti-Static Precautions.
Physically install the graphics card. Plug the monitor into the graphics card. Close the computer case.
Plug the computer into power. WAIT 1 minute, turn the computer on.
IF you do not, you stand the chance of driver conflict.
To explain;
When a device (Such as this graphics card), is installed on a computer, Windows 'break it's neck' to find suitable, matching drivers.
THOUSANDS of generic, one size fits all, drivers.
This = NO.
Could cause a driver conflict.
Windows: " Which drivers do I use? These or THESE?"
[ If you install the graphics card FIRST, THE drivers are NOT there.
Then you go back, and do install the drivers, there may be a driver conflict ]
Drivers:
Small pieces of software that allow the Operating System to communicate with a device.
Some O/S examples are Windows XP, Windows Vista, and Windows 7.
The graphics card is an example of a device.
[ When you put the Installation Disk in the optical drive's tray, and close it, the graphics card's software will come up. Go for the option with the 'Control Panel', AND drivers.
Example; For an ATI Radeon graphics card, the 'Control Panel' is ATI Cataylst Control Center ]
3helpful
2answers
Sound can not be played on my system and asked about audio out put device
this is happening when the sound card has no driver ...probably you downgraded to xp from vista or windows 7 and now you do not have the suitable driver for xp...
If this is a brand computer ...than you can look on the manufacturer's site for the sound driver ....(for xp) if it is not...and it is a desktop....open it and take a look at the sound card if it is a pci card...and let me know the name ..and model...if it is an on board card ..than I need the motherboard name ...
If the computer came with a driver disk ..and always used Xp ..but now you just reinstalled it ...look for the sound driver on the mother board disk ..or separate disk if it has a PCI card ..
(the pci card for sound is just a separate card ..that is inserted in a pci slot ..that is why its called that way ...and its different from a on board ..one just by that...The on board cards..always have the drivers on the disk that came with the motherboard..)
Im waiting for an answer and will see whats to do further..
2helpful
Install a parallel pci card on Windows 7
1helpful
2answers
Top Creative Labs Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
