Question about HP Compaq Presario CQ50-110US Laptop
Hp compaq presario cq50-110us hard drive overheating
First what I did was notice that I power up the and got a black screen. pulled it apart and got the same issue. used my LCD TV as monitor. ran the start up diagnostic on the DVD Windows 7. the screen came back. But now I am get a hot Hard drive. and now will not boot from hard drive. I am thinking all along the it was the hard drive causing the problem, am I right?
Larry Ng
  • HP Master
  • 5,978 Answers
Yes you a are right. or both,
fix hdd first.
i cant tell because i cant watch you do all that.
the order and timing of those tests and events right?
ever run SMART< see what the drive temp is., it tells you.
85-90f is normal.
why not just boot the PC to linux stick first or CD/DVD
see if screen works, end the drama?
the fix that or the bad drive,
is the fan dead, that it, the 2.5" drive never get hot.
unless outdoors in the sun and the fan fails, and like I said cant see you or where you are. there.
IS hot only warm? warm is normal for all HDD, mead.
and 15,000 rpm super hot is normal. in fast DT.
your s is 5400 rpm drive my guess.
cool running.
the PC is old right, and like most Old PC and dogs
lots of issues, never seen on old and not lots bad.
ever. and virus infected.
Posted on Sep 12, 2017
TTCCYLife
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 33 Answers
No. your notebook monitor backlight has broken.
5 Related Answers
Anonymous
  • 85 Answers
SOURCE: hp pavillion zt 1170
I am pretty sure you have a corrupted operating system here, or have somehow gotten corrupted video drivers. Boot to safe mode and change the video drivers to Microsoft VGA Generic and reboot and see if that fixes it, If it does, you can experiment with installing updated drivers for that machine available on the HP web site.
Also run a disk check on all drives; sounds like you might have some data loss.
If this does not fix it, consider reinstalling the operating system and then patching it to the highest level possible.
If reinstalling the OS does not work, you might have hardware problems with the screen or motherboard, though this is pretty rare, and is a different matter to troubleshoot.
Good luck...
Posted on Nov 29, 2007
Anonymous
  • 163 Answers
SOURCE: hard drive controller
These can be fun and Hdd/IDE/SATA Controllers on Desktops are different than laptops.. Embedded controller chips as well as the Northbridge/Southbridge chips are integrated to everything else and its a nightmare to track down period. (Ive had to replace Integrated Modem chips to cure a Boot or BSOD error that states the Video Adapter needs to be changed) ..(Generally due to Power surge or other).. You are on the right track however and I'd just suggest running Memtest of the Knoppix to start be4 I can say other. Is there Shared or dedicated RAM for the GPU on this one? They manned both ways depending on the specific board revision..
Talk soon, Ken
www.ikenfixit.com
Posted on Feb 15, 2008
Peter Toth
  • 159 Answers
SOURCE: HP Pavillion dv6700 - black screen
Do the following without the battery inserted.
Let the computer sit with no battery for 24 hours. Do not put the battery in at all. Try using your original memory stick ONLY, with no hard drive and see if it will POST. If it does, insert the hard drive and try again. Could be the new memory...
Another thing you can try is reseating the processor. Turn the ZIF screw, take the processor out (WATCH THE PINS!!) and put back in GENTLY. Leave the memory in the computer, hard drive removed, try to power on.
These models have been known for bad motherboards. Contact HP and arrange to send it in. If you do enough digging on HPs website, you'll find the service advisory.
-Dell & HP Certified Technician
Posted on Oct 29, 2009
Anonymous
  • 32 Answers
SOURCE: My Compaq Presario F730US Laptop will not start
As I have mentioned in the past these problems are usually connected with improper partioning with the hard drive. My suggestion would be to use FDISK to check for partitions that are marked as not being used.
Be Careful when using Fdisk because it can and will sometimes backfire.
(you can find Fdisk on just about any startup disk
Just make sure that there are startup files on the disk
Posted on Nov 15, 2009
pomeroycomp
  • 20 Answers
SOURCE: Compaq Presario CQ50-110US...blank screen, no display
Can you see what's on the screen if you hold it under a light? Did the screen die suddenly or were there more symptoms?
Posted on May 05, 2010
My Compaq presario cq70-120us wont work =P it needs a new hard-drive, and currently is without one, when i plug it in and hit the power button, it turns white, but the screen remains black without any...
i would expect to see the compaq logo come up, and you should be able to "post" (ie bring up the bios or a diagnostic screen) even if there is no functioning hard drive.
at least I would expect it to pop up with something like operating system not found,
you might be better off replacing this one (sorry)
Oct 17, 2010 | HP Compaq Presario CQ50-110US Laptop
Starts but black screen, white curser flashing.
your hard drive is failing. try a system restore and if that does not fix the issue you need to buy a replacement hard drive
May 13, 2010 | HP Compaq Presario SR1820NX (ER919AA) PC...
How to remove HDD in compaq presario sr2030nx
After removing the side cover, you will notice 4 black tabs behind the front bezel under the hard drive, bend these back just enough to let the front cover release at the bottom, then press the green square at the top to release the front plastic bezel. After you carefully pull the front off, you will need to remove the cables [power and IDE] pull up on the green tab that locks the guide screw on the hard drive and push it forward out of the case
Dec 11, 2009 | HP Compaq Presario SR2030NX PC Desktop
My compaq presario power is Ok but have completely
I would assume that your hard drive is spinning? If not your system will not boot because of a faulty or missing harddrive. Last known good config only works on the operating system and would not work during POST. Can you give a little more information please?
Fehdi
Aug 19, 2009 | Computers & Internet
My compaq presario stays on the 1st screen that says COMPAQ and will not change screens no longer how long I wait.
Pull out your hard drive, it is probably stalled on a malfunctioning piece of hardware. Once you pull the hard drive out, try to boot it up. It should say something like No OS found.
If this doesnt work, repeat but try the RAM, wireless card, battery, etc.
If none of these steps work then you will need to replace the motherboard
Aug 02, 2009 | HP Compaq Presario V2000 Notebook
V2311US overheating and shutting down
Try to clean heatsink and fan. Make sure fan is spinning(common problem).
Mar 20, 2009 | HP Compaq Presario V2311US (EC186UA) PC...
Compact Presario v2000 the screen is blank
Remove the power cord. Remove the battery. Hold in the power button for up to 60 seconds to discharge the laptop. Try booting it.
Apr 27, 2008 | HP Compaq Presario V2000 Notebook
Screen display problem
sounds like a loose ribbon cable from the MB to the screen.
Here is a manual that should help you take it apart.
http://h10032.www1.hp.com/ctg/Manual/c00444244.pdf
Dec 01, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario CQ50-110US Laptop Logo
59 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
