When I turn on and press the start button all I get it tries to start then flashes the F2 error code. I went through the testing mode and with both test in the technical manual The F2 code would come up but all the functions by pushing the buttons gave a good reading, but remains on F2. In the manual test it passes all test in the manual and starts the motor. From this I want to know what part you suggest the electronic control P/N 8564394 or P/N Control Electronics P/N w10111617.
SOURCE: New Machine Control Electronics needed?
HUH????? just change interface(buttons and board ) have never took time to ck resistance.. front interface just tells machine control what to do
SOURCE: sears elite he dryer stopped working
Bad control panel. Replace the control panel at repairclinic.com. When your control panel clicks like that it means that a resistor or solder joint has gone bad and it is cheaper and easier to just replace the board
SOURCE: Kenmore dryer model #84052
check for broken belt ,bad thermal fuse, broken door switch or is it in control lock mode? let me know if you need any more help
SOURCE: dryer wont start when button is pushed
Did you check the door switch? Electronic control could be an issue but start with the basics and you have covered most of them already... good job.
Eric
SOURCE: Kenmore electric dryer Model 63932:
The motor relay is probably shot.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
