Question about Toys
I have a Yamaha Raptor 700r battery powered atv, I have a new charged battery and when it is installed the battery power indicator lights doesn't light up at all. I know the battery works because I use it on a Yamaha 660r, which has an off/on switch. Could the 700r just be turned off or does it have a fuse somewhere?
Posted by Gabriel Reyna on
auxialiary
    Problem Solver:
  • 9 Answers
Assuming the Raptor does not start:
The main fuse and the fuse box are located under
the seat. There should be a spare fuse there also. Turn the key to
OFF and turn off all electrical circuits. Replace any blown fuses.Turn the key to ON and turn on the electrical circuits to check if the devices operates. If the fuse immediately blows again, have a Yamaha dealer check the electrical system.
I found this in the online owners manual at this site:
http://www.yamaha-motor.com/assets/service/manuals/2008/LIT-11626-21-12_Raptor700_SE_1516.pdf
Maybe the manual will help troubleshoot your problem.
Posted on Jan 05, 2014
5 Related Answers
Anonymous
SOURCE: no power supply to gearbox
It has a thermal fuse. Depress the gas pedal for 25 seconds and try it then
Posted on Apr 18, 2009
Anonymous
  • 53 Answers
SOURCE: Don't know how to charge Fisher Price ATV battery
You can print these instructions.
http://www.fisher-price.com/inst_sheets/H7332pr-0920.pdf
Posted on May 05, 2009
Anonymous
  • 867 Answers
SOURCE: IGNITION PROBLEME
make sure the battery cable going to the engine block is not corroded , as this is an older bike.clean screw and connector with wire brush, put vaseline on them.
Posted on Jun 15, 2009
Anonymous
  • 4 Answers
SOURCE: Need charging instructions for Air Hogs Havoc
1.Take out charging wires. 2.turn off your heli and insert charging socket into your heli's socket. 3.the charging green light will light up while charging. 4.charging complete, the green light will turn off. 5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
Posted on Jul 21, 2010
Zzwoz
SOURCE: Megatredz yamaha raptor 12v, 12ah keeps blowing
Pop out foot switch and switch wires to other side of the switch. There should be a color code sticker on switch.
Posted on Aug 04, 2011
Hi there I washed my raptor 700 2016 model now it want start doesnt even turn over
Let it dry out. You got the electrical wet with high power water pressure.... Wd 40 may help dry out the water .. Check to see if your fuses are still good and you didn't short them out.
Jun 09, 2018 | Yamaha 2008 Raptor 700R
Why won't my kids Yamaha raptor 700r 12 volt ATV start
faulty switch/toggle
loose wire to motor
battery not holding charge
belt driven
May 01, 2017 | Yamaha Motorcycles
Just bought a used yamaha 700r raptor for my kids, battery is fully charged and tested on another vehicle and it works. Not getting battery indicator to show anything. Any suggestions?
Try jumping the cylinoid post with a screwdriver with the key on if it starts you have a bad cylonoid most likely,if this is the case order a new one from amazon.com as they are much cheaper and good quality as to buying one from a bike shop
Aug 30, 2015 | Yamaha Motorcycles
Not gtting fuel
service carb, carb float needle and seat, petcock, main and idle jet in the carb and you should be good as new.
Mar 15, 2014 | Yamaha 2007 Raptor 700R GYTR Edition
Raptor 700 has fuel compression and spark but wont start?
i am having the same problem with my 660r if i can figure it out on mine i will let you know for yours but if any one else can help us both that would be cool 2 lol
May 16, 2010 | Symantec Rc Yamaha Raptor 700r Atv Blue ...
Toys Logo
635 people viewed this question
Top Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
