Question about RCA Video Cameras
Battery losing charge
Camera turns off minutes after putting in fresh batteries
4 Related Answers
Anonymous
  • 104 Answers
SOURCE: Charging Battery
maybe your battery is dead, put your battery in your freezer for one night and charge it again.
Posted on Jan 21, 2008
Anonymous
SOURCE: new nikai DV925 video cam
go buy a new camera..
Posted on Oct 30, 2009
Anonymous
  • 71 Answers
SOURCE: my camera won't turn on, even with fresh batteries.
u need not get new camera.use an iron metal to sctrach the bateery terminal of the cameral then put the battery.
Posted on Dec 10, 2009
Anonymous
  • 3 Answers
SOURCE: Red "faulty battery" indicator with newly-charged Batteries
You can buy new batteries and buy the one it says to buy on the package.
Posted on Apr 09, 2010
Took out memory card to transfer photos. returned card to camera and it indicated memory card error shut down leaving lens out.
Never remove or insert a memory card while the camera is turned on. Try removing the battery, waiting about 30 minutes, and then putting in a freshly charged battery.
Never remove or insert a memory card while the camera is turned on!!!!!!
Jun 22, 2014 | Pentax Optio Cameras
Change the batteries message keeps appearing even with fresh batteries. The camera turns on then immediately turns off What's up?
This actually a really common problem among Canon point and shoot cameras. There are a couple of methods that have worked well for others.
1. Open the battery compartment and remove the batteries. Then take a regular wooden pencil and place the eraser end down onto the battery contacts. Rotate the pencil to remove any corrosion. Sometimes a lack of proper battery contact will result in the low battery indicator.
2. Take a toothpick and wedge the tip under the battery contact and break it off. This will put more pressure between battery and contacts.
You can also try installing 3rd party firmware at http://chdk.wikia.com/wiki/CHDK_in_Brief
This is a bit technical and will probably void your warranty, but might be worth the try.
May 08, 2011 | Canon PowerShot A460 Digital Camera
Every time I turn the camera on, it takes 2 to 3 minutes to come on and always makes me verify date and time. Why?
This usually indicates that your rechargeable Li-Ion battery is starting to lose its ability to retain adequate charge due to age and usage (about 500 charges or 18 months of 'normal' use). Try putting a new rechargeable Li-Ion battery.
Hope it helps!
Jan 16, 2010 | Kodak EasyShare V1003 Digital Camera
I have a samsung 860 digital camera ang my problem is the lens... the lens is still retracted even its turned off... before it happened the camera have a low battery.. and when i charged the battery for...
This may be similar to another solution posted. Try heavy duty batteries - I used ACDelco Super Alkaline, but any brand of "heavy duty" AA should work. Make sure battereis are not cold; low temp causes any battery to lose power. If fresh heavy duty batteries do not help, it may need professional service. (DO NOT try to force the lens back to retracted position - something WILL break.)
Dec 18, 2009 | Samsung S860 Digital Camera
My camera won't turn on
Take out the battery for like 10 minutes then put it back and turn it on.
It it doesnt work, then try putting a freshly charged battery on it.
Aug 31, 2009 | Nikon Coolpix 3200 Digital Camera
The main batter will not hold its charge when left in the camera.
After 12 months use camera batteries will not hold a true charge, but they can still be used for clocks, or remotes. Buy new ones. We all have the same problem.
Mar 08, 2009 | Sony Alpha DSLR-A100 Digital Camera
Charging Battery
Jan 21, 2008 | Video Cameras
Digital Camera
Unfortunately this camera is very bad for battery life because the zoom lens itself takes up alot of power. I would have the same problem with putting fresh batteries in and they would only last a couple of minutes.
I went to Blacks and asked their opinion and they suggested a Lithium Ion battery which came with the charger.
The charge only takes 30 minutes and I have been using my camera all week and the batteries are still going strong!
The price for the pack and charger together was a about $29 and it was totally worth the money
Jan 20, 2008 | Canon PowerShot S3 IS Digital Camera
Battery problem
did you use comapny authorised battery if not go for it
Apr 24, 2007 | Canon PowerShot S1 IS Digital Camera
Focus error is displayed in my Camera...
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it. Never put in a freshly charged battery in any unit, let the battery cool down for five minutes or more, a freshly charged battery has higher voltage or power than normal battery and you may have a chance to damage your unit. Some people will say its not true cause they are doing it for a long time, they are just lucky I may say. Never take bad chance if theres any.
Aug 18, 2006 | Fuji FinePix S5000 Digital Camera
Video Cameras Logo
Top RCA Video Cameras Experts
Lawrence Oravetz
ADMIN Canada
ADMIN Canada
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
