Question about Fisher and Paykel DG05 Gas Dryer
I want to reset the fuse on my paykal and fisher model number DG05
I need to know where the fuse is located how to get to it and to reset it
2 Suggested Answers
6ya staff
SOURCE:
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: As long as you hold the start button in, the
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jun 25, 2010
Bmw328 convertible electric roof will not open
The fuse is located next to the battery in the trunk
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
Feb 12, 2018 | BMW 328i Cars & Trucks
How do I reset the "Change Oil" light on a 2000 Pontiac Grand Am?
Hello tiffinkie: My name is Roger an I will help you. First open the passenger door and locate the fuse panel located in the end of the dash cover. Remove the cover turn the key on. Do not start the motor. Push the reset button located at the top of the instrument fuse panel.The CHANGE OIL light will start to flash.Press and hold the RESET button again. The reset is complete when you hear the chimes sound and the CHANGE OIL light goes out. Should you need further help please just ask. Please rate your answer. This way I know it was helpful. Thank You for using Fix Ya. Roger
Jun 18, 2010 | 2000 Pontiac Grand Am GT
2004 f150 will not start need to find where the fuel pump fuse is
FUEL PUMP FUSE IS A 20 AMP FUSE LOCATED POWER DISTRIBUTION BOX INNER FENDERWELL IN THE ENGINE COMPARTMENT.ALSO CHECK THE INERTIA SWITCH LOCATED BEHIND PASSENGER SIDE KICK PANELTHIS WILL SHUT OFF FUEL PUMP.IF YOU RUN OVER A POT HOLE OR SOMETHING.CHECK TO SEE IF SWITCH BEEN KICKED OFF.AND RESET IT.
Mar 28, 2010 | 2004 Ford F150
Cigarette lighter out
yes there is it is more than likely located in the insde fuse box but you will need to located the box and your vehicle book to know which fuse you need to replace if you do not have a book you can either order one or use a fuse tester to figure out which fuse has blown
Jan 17, 2010 | 1999 Saturn SL
Turns no heat continues to run? roper dryer model # red4340sq1
you need a Thermol fuse. This part is a non resetable fuse. you will need to replace it. it is located in the back of the dryer. you will need to take off the back panel. let me know if this helps
Oct 12, 2009 | Roper REX4634KQ Electric Dryer
MAYTAG DRYER PYET444AYW HAS NO POWER...IS THERE AN INTERNAL FUSE?
There is an internal fuse. It is called a Thermal Fuse. It is not resetable it is only replaceable. It is located in the back of the dryer. Unplug the dryer and locate the thermal fuse and replace it. Two wires conect the to it. Also I would check the breaker to the dryer. Thanks and good luck. I you need futher assistance let me know and we will get through this together.
Aug 24, 2009 | Maytag Dryers
Dryer quit working
Hi, The only thing you can reset is the beaker for the dryer in you breaker panel for the house. As far as the dryer, if it doesn't start at all, you will need to test the fuse in the dryer. First thing!! Unplug the dryer. This fuse is none resetable. Most models have the fuse located in the back of the dryer. You will need to remove the rear panel and locate the fuse on the blower housing. The fuse is white and is 1/4" wide and about 2" long with two wires attached to it. If the fuse has coninuity, then it is ok. This is the most common problem. Other causes could be door switch, timer, or the motor.
Hope this gives a little help. Need more, let me know
Vic
May 09, 2009 | Kenmore Dryers
Fisher and Paykel DG05 Gas Dryer Logo
Top Fisher and Paykel Dryers Experts
Nathan Van Boven
Nathan Van Boven
Bill Eager
jimorris77
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
