Question edited for clarity.
Question moved to model category.
No, it is no a replaceable item and is located in the bottom of the fuel tank and is part of the fuel pump
Attached to the fuel pump in the gas tank. It's not a replaceable part. You would have to replace the pump in the tank. Actually it is replaceable, but not a maintenance item. Apr 12, 2011
Hello. It seems your car's TCS Traction Control System is malfunctioning; causing the torque converter to stay 'engaged' to the engine. This will stop the engine from running when your car is in any drive gear. I don't know what your car's electrical problem is. Good luck and keep me informed; if you want to.
I would check the main fuse relay aka fuel relay... Located under the dash, on the steering colum... They go bad with the heat.. I have an 01 cl and would act stupid on hot days and that relay fixed my issue...
This sound like a classic fuel delivery problem. Start with changing the fuel filter(s). If they're dirty they might work fine under a smaller workload but begin to fail as the car starts climbing because there isn't enough flow to match what the engine needs. Then have the fuel pump tested. Changing the O2 sensor is a good idea. Cheap, easy, never hurts. I doubt seriously that your cat converter is clogged on an '01. Make sure you have a good air filter. The last step I would suggest is have the injectors tested. They might be clogged enough that they work fine under normal conditions but not well enough for heavy strain. Dealership mechanics don't work for you. They work for the dealership. Find a reputable and qualified private mechanic for testing and servicing. They don't charge as much and they get paid by you, not the dealership.
