Question about Pioneer AVH-P4400BH
Avh-p4400bh buttons stoped working
Radio kept truning the volume up on it own till it was maxed out, only holding mute button would stop it. no other buttons work either on the button strip or on the HU face itslef
5 Related Answers
Anonymous
SOURCE: Pioneer AVIC-D2
OK, I spoke to Pioneer tech support and they had me go to destination>settings>connection status. If the parking brake shows "off", many of the functions will not work as a safety measure. I guess this is their version of interlock. I think it can be defeated with a wire-around, but thats what they say the problem is.
Posted on Jan 04, 2008
hogan doan
hogan doan
  • 227 Answers
SOURCE: Volume Button on steering wheel not responsive!
There is a metal dome under each button, some time they became warped or inverted and you don't get the actuating contact on the first push but if you keep on pressing it eventually contact will be made and whoalaa actuation happened. If you are technical incline you can replace it with a dome of similar size of a device you no longer have use for, like a remote control, an old car stereo or telephone...ect. Goodluck.
Posted on Mar 05, 2008
Craig Sagar
  • 11 Answers
SOURCE: Can I use avh-p6500dvd radio with avh-p6600dvd brain.
hi i have the same unit but i dont need a brain for mine what is it your needing the brain for
Posted on Nov 28, 2008
Anonymous
  • 111 Answers
SOURCE: No picture on display, buttons dont work
The problem is the ribbon cable,and you right there is a recall for this model,you need to contact Pioneer at pioneerelectronics.com and they should repair it for you at no cost.
Posted on Dec 02, 2008
turbo tunes
Steve Karner
  • 26 Answers
SOURCE: No audio an Avic-n1 and Mute button display
We can fix this and all other AVIC N1 N2 N3 problems.
Please visit www.turbotunes.com for affordable AVIC repairs.
-Steve
Posted on Apr 06, 2009
How do I set the station memory buttons?
Ok...go to the station you want to keep and push on button 1 and hold till either it blinks and stops or volume will mute then come back on. Then go to next station and hold "2"....on down the line
May 19, 2016 | Pioneer Audio Players & Recorders
Ignition off radio works, ignition on radio mutes
i would also check the mute or volume buttons on the steering wheel. spray them with a can of compressed air, hold the volume up and spray the minus and vise versa. hope this helps.
Mar 30, 2014 | 2007 Mercedes-Benz C230 Sedan
2003 chevy silverado, cd/cassette/radio, has no volume, it lights up, all the dials appear to be working with no sound at all, like it is muted. I can't find a mute button listed in the manual. My...
Sometimes these radios have what is called a logic lock up. First thing to try is to remove BOTH positive and negative cables from the battery. Then while holding both cables away from the battery, touch the metal ends of the cables together and hold for 20 seconds. This will usually reset locked electronic modules. Hook them back up to the battery and try radio.
Jan 26, 2018 | 2003 Chevrolet Silverado 1500
My volume and mute button has stopped working all other buttons are functioning properly
Press the mute button and then turn up the volume button. If no sound still then press the mute button again. If we are talking about a Remote, then change the batteries.
Apr 08, 2010 | Audio Players & Recorders
All over sudden my boston horizon doesnt allowe increase the vol.
To fix: turn on unit, turn volume all the way down to 00, push and hold volume button for 10 seconds until beep then release, then turn volume all the way up to 50 (max) and push and release volume button.
May 17, 2009 | Boston Acoustics Duo-i Horizon Clock Radio
How do you get the Pioneer DEH-P670MP car stereo cd player off of mute?
hi there
to fix this press and hold the source button till unit turns off the source button switches from CD - radio...................once your unit powers off........press and hold the function button down till the clock appears in display you should also hear a beep when this happens.........press the function button repeatedly until the telephone feature appears now switch by pressing the skip button to ATT (Attention) once this is done press the source button to power on the pioneer unit simply turn up the volume and problem should be solved......
hope i was able to help
Feb 21, 2009 | Pioneer Premier DEH-P670MP CD Player
Forgot my security code
the guy that wrote how to unlock the receiver left the most important parts out... guess dint wanna be helpful...
Bypass code for radio that our locked
Thank you for your e-mail. Put in the same number 3 times (example 1111) until it locks and then push in the mute bottom and hold it and while you hold the mute button with your other finger push in the volume control (power button) and hold both of them until a new screen comes up and then put in 122164 and hit OK and that should work.
let me break it down you do not need the remote...
first put the same number in (e.g 1111 enter this number 3 times) second after the device locks on the radio hold the mute button while holding that press in the volume nob (e.g power button) hold them both till another screen comes up and enter 122164 and press ok and your all done... this solution works on all dual indash dvd players
Feb 16, 2008 | Dual XDVD8181 Car Video Player
Projection lamp timer reset
I called 1800 211 PANA and they walked me through resetting lamp.
press recall and Volume- till solid screen shows, then hit recall till you see codes on top left, then hold volume- and mute(same time) till all codes return to 000000000000, then hit exit. turn off tv and check to see if it works
Jan 21, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Pioneer AVH-P4400BH Logo
818 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
