Question about Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher
Rotor is melted to tub how to Remove And replace
How to remove rotor
1 Related Answer
Sam
  • 3247 Answers
SOURCE: F2 code. Followed listed
There are no wires underneath the rotor - it is just suspended in the cavity. So you cannot do any damage except make scratches around that area. Maybe take a straightened wire coat hanger and insert from the side hole in the filter sump area. You might be able to push the rotor up to an extent and then grab it with pliers.
Posted on Nov 08, 2009
How do i get to the rotor position sensor on a fisher paykel gwl11
This is a common issue and is due to corrosion inside the RPS, You need to lean the machine back and remove the rotor cover (round with a nut in the middle), Then remove the 4 x 3/8" bolts and drop the stator down. you can then remove and replace the RPS, I have repaired a lot of these and have not yet found one that was fixable by cleaning the connections.
May 04, 2014 | Fisher and Paykel GWL11 Top Load Washer
Tip
Replace Recoil Rope on Lawn Mower Engine
1) Remove the recoil housing
**NOTE: normally you DO NOT need to remove the rotor pulley or spring to replace the rope.
This is the area that causes so many guys a lot of extra trouble!
2) Locate the string that is left and the hole it is threaded thru
3) Determine how much string has broken off of the rope that came out
*Note: if more than 1 inch is left, then the rope needs to be replaced
4) Obtained a length of rope appropriate for your engine, it is always better to have too much rope.
You can always shorten if it is too long.
Make sure both ends are melted to a point for easier threading thru handle and rope rotor
5) Wind the rotor in the direction of what the rope would pull,
(this will tighten the spring) until the spring is completely wound.
Remove 1/2 to 1 revolution.
6) Install the rope (with the handle installed on one end) thru the recoil housing and towards the rope rotor.
Tie a knot in the end of the rope, leaving a 3/8" tail free.
Then allow rope to wind onto the rotor until all rope is wound.
8) Pull the rope several times to position rope properly into rotor.
*note : there should be NO droop in the handle after released
9) When the unit is functioning proplerly, re-install housing onto engine.
on Dec 04, 2009 | Garden
Need to change stator and rotor assembly in WM2688H*MA
The stator is stationary mounted to the outer tub the rotor attaches to the spindle of the basket which is a shaft that goes thru a bearing to get a definitive answer remove the back panel remove the rotor turn the center bolt till it loosens keep going as this will back the rotor off the stator you will have to pull with a little effort strong magnets to get it off now try to spin the basket by hand if stiff you have a bad tub bearing.
Apr 02, 2014 | LG Washing Machines
What does the lr code mean
The code means locked rotor. Disconnect power to the washer and remove the rear access panel. Remove the rear access panel securing screws and pull the panel off the cabinet.
Turn the drum pulley by hand to determine if there's a restriction that caused the locked rotor error. If there's a restriction, remove the drive belt. Pull the belt from one side of the drum pulley then turn the pulley in such a way that the belt unwraps from it.
Turn the drum pulley and the motor pulley to determine whether the drum or the rotor is being restricted.
The outer tub bearing is damaged if there's restriction in the drum pulley. Specify the model of your washer for the specific replacement part/s and installation guide.
Try to free the rotor if it is stuck by forcibly turning it back and forth. Replace the drive motor if the rotor cannot be unstuck. Specify the model of your washer for the specific replacement part and installation guide.
Mar 01, 2010 | Maytag Neptune MAH5500B Front Load Washer
Starter rope pulley will not pull the rope back into the leaf blower.
Most commonly, the recoil rope rewind spring is broken. However, inspect the recoil housing assembly first to make sure no debris or rope fragments have prevented the rope rotor from rewinding. Always remove the spring 'AS A LAST RESORT'. Many rewind problems can be solved by inspection of the rotor and not have to remove the spring. In case you do, I will include instructions on how to re-install.
1) remove the recoil housing
**NOTE: normally you DO NOT need to remove the rotor pulley or spring to replace the rope. This is the area that causes so many guys a lot of extra trouble
2) locate the string that is left and the hole it is threaded thru
3) determine how much string has broken off of the rope that came out
4) after rope is obtained, make sure both ends are melted to a point for easier threading thru handle and rope rotor
5) install the rope (with the handle installed on one end) thru the recoil housing and towards the rope rotor.
6) with the rotor free of tension, route the rope from the groove toward center and up thru the hole. Tie a knot in the end of the rope, leaving a 3/8" tail free.
7) wind the rotor in the direction of what the rope would pull (this will tighten the spring) until the spring is completely wound. remove 1/2 to 1 revolution, and then allow rope to wind onto the rotor until all rope is wound.
If droop is evident, wind the rotor and rope 1 revolution tighter so there is no droop of handle when released
9) when unit is functioning proplerly, re-install housing onto unit
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 21, 2009 | Craftsman Garden
How do you replace front bearing assembly on 2000 f-150
After you get the wheel off; remove brake calipers...do not allow them to hang down - you'll damage the brake lines!
Remove the grease cover at the center of the rotor with a flat blade screw driver. Remove the castle pin and nut, then the rotor should slide off the spindle with very little effort.
To remove the bearing raceways...clean the grease out of the center of the rotor...so you can see what you're doing. Place rotor on a solid bench/cement pad, so you can get a flat chissel/large screw driver to the inside of the rotor...pound the raceway out, working around the rotor in a circle - the raceway needs to come out evenly to avoid damage to the rotor. If you can't get the raceways out - take the rotor to a machine shop that can do it for you (sometimes the auto parts store will help...if there're not busy).
GOES BACK TOGETHER IN REVERSE ORDER:
The best thing to do is get pre-packed bearings, new castle pins and a tub of axle grease.
Remember, put about 1/2 cup/palm full of grease into the center of rotor prior to re-assembly. Also, don't over tighten the wheel...put the castle nut on and finger tighten. slightly tighten with a wrench...ensure the rotor turns freely - must be snug and slight resistance should be noticed. Don't forget the new castle pin.
Hope this helps,
Mike...
Nov 20, 2009 | 2000 Ford F150 Flareside SuperCab
STEP BY STEP DIRECTION. REPLACE STARTER ROPE. MIGHTYLITE BLOWER MODEL #UT08520
Nov 14, 2009 | Garden
CAN'T FIGURE OUT HOW TO RE-STRING PULL CORD
Nov 13, 2009 | Poulan Garden
I pulled the cord off my homelite 2 cycle leaf blower. can it be fixed?
Yes,
Nov 08, 2009 | Garden
ROTOR BURNING UP
The rotor is somehow making direct contact with one or more distributor contacts.
Check the contacts inthe cap to see if you find any physical damage to one or more contacts caused by the rotor.
Could be rotor lead too long (file it down) or maybe the distributor shaft is bent or not seated. Remove cap and observe the distributor shaft as someone cranks the engine. Does it wobble? Can't tell? Place a stiff reference parallel to the shaft and turn engine again.
Oct 07, 2009 | 1996 Chevrolet Suburban
Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher Logo
111 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Paul Bade
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
